id think you'd want it as thin as possible so that it doesnt screw up the mounting locations...
Remember im not using regular bolts, im using countersink screws, that are designed to be used this way. Fully tightened im seeing the big 14mm ones sticking out of the hole maybe 1mm at the most, which a washer is about 2mm thick, so its hardly anything.
No hard feelings!
