Mazworx wrote:I gotta say, after reading this thread, it seems Craig blows everything out of proprotion. Let me discribe to you how this adapter plate works. The dowel pins on the engine line up to the adapter plate and the dowels on the adapter plate line up the trans. So when assembled, the centerline of the engine is lined up with the centerline of the trans. The bolts on the adapter plate and bellhousing just hold the pieces together. The dowel pin holes are machined to a .002" tolerance and the bolt holes are just drilled to a clearance (+1/32").
You ask, why was the hole off in the first place. Well as I discribed to Craig and Nick, when we initially probed for the bolt pattern, we used the stock bellhousing. The stock bellhousing holes for the bolts are not even machined, they are casted, so the bellhousing holes didn't represent a good centerline. But the dowel pin holes were machined. So the second time around we used the dust shield and that worked to get the proper locations.
This kit is a custom setup that no body else has produced. We have sold over 150 SR, KA, L, VH adapter kits. This is the first problem we had in the past 2-1/2 yrs. When this problem was brought up to me (after selling about 10 VH kits), we decided to go back and take a look at the issue. After testing one of the plates out on a project car we started working on, we had to drill the hole to the next size to get the bolt to clear. Once again, these are clearance holes and not location holes. Once we did that , everything worked out good. Mind you, the dowel pins lined up perfect, all the other holes were good and the bellhousing mated up good. So to say the adapter didn't fit is not an accurate statement. Because you can bolt everything together and run it without that bolt and still not have an issue. I know it should have been right in the first place, but to come on here and throw a fit is kind of ridiculous.
We do our best to support the community and Nissan enthusiasts who want to do crazy swaps and push the limits of their cars. We are not perfect, so if there is an issue, be patient and let us try to resolve it.
Modified by Mazworx at 5:26 PM 6/16/2008
Mark,
I'm not going to speak for Craig, but my perception is that some of what you see in this thread is a combination of venting and a play-by-play update. If you look under the thread "Road Terror Z" you'll see gsiguy providing an update on how the Moates Ostrich2 product is having issues with the Nissan ECM - same type deal, without a lot of the venting, but Moates hasn't had an opportunity to respond either - it's just the play-by-play. I do agree with you that the bolt hole didn't present a safety or performance issue as we spoke at length about it on the telephone.
Additionally, you were very flexible in the resolution to enlarge the hole/get credit or get a new plate if we felt strongly about it. Now, as I mentioned on the phone, I don't think enlarging the hole would've been a challenge, at least for me, if it wasn't for the countersunk hole needing additional work to clear a thin wall socket. For $500 my expectation was everything working "out of the box" especially considering this is a custom part as you mentioned earlier.
At the end though, we both did receive the replacement plates, and as far as I know from speaking with Craig, he told me his "fits perfectly". I did want to close the loop that the replacement plates were 100% correct.
Now I haven't done mine as I spent a lot of time this weekend with the family for Father's day, etc. But I trust that if it worked perfect on Craig's it'll work perfect on mine as well.
That's my thoughts on this matter, Craig can chime in if he feels differently.
Thanks again for taking care of all this.
Nick.
