240_Keyy wrote:Hokiruu - A T28 will flow more air at 14psi because it has a greater efficiency and the air is "cooler" and therefore denser than the same 14psi from a T25
Stay at 10psi with a T28 and stock 370's
SWIFT_DRIFT wrote:efficency wise the s14 t28 is the same as the s13 t25, meaning around 13-14 psi. you might push it to 1 bar (or 14.7 psi)
ImportIntelligence wrote:21psi - stock injectors, SAFC and walboro. Just barely starts to lean out at 6000+ RPMs
