mass air flow
snowdrifts13
Car: 1991 nissan 240sx
my mass air flow senser is jacked. my engine is a stock ka24de and i was wondering if i could put a 300zx nonturbo one in my ka, or if i should just get another ka one?
codyace
Car: S14 w/redtop
How do you know it's 'jacked'?
You can't put any other sensor on, but the one that came with your car, unless you're ECU is retuned for that specific MAF.
snowdrifts13
it has a weird smell everyonce in a while, and sometimes when i stop at stop signs it shuts off. the guy i work for who is teaching to be a machanic thinks thats what it is. but i also read here on NICO that improperly changed oil filters can make a bad connection on your MAF. my oil filter dont leak or anything so i thinks just bad and i was gana get one from a 300zx non turbo but i wanted to make sure first.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
snowdrifts13 wrote:it has a weird smell everyonce in a while, and sometimes when i stop at stop signs it shuts off. the guy i work for who is teaching to be a machanic thinks thats what it is. but i also read here on NICO that improperly changed oil filters can make a bad connection on your MAF. my oil filter dont leak or anything so i thinks just bad and i was gana get one from a 300zx non turbo but i wanted to make sure first.
Are there any more smilies for cunfused?
Your oil filter has nothing to do with your MAFs
Gundam1s
Car: Black 1995 240SX SE
codyace wrote:How do you know it's 'jacked'?
really now...
Good luck with your maf.
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
I dont have a maf sensor on my car and I have to buy one so if I buy one I have to have my ecu retuned!?!?
IanS
destroyyourmind wrote:I dont have a maf sensor on my car and I have to buy one so if I buy one I have to have my ecu retuned!?!?
You need to buy one from the same model car, if its for a SOHC 240, you need a MAF from an SOHC 240, if its for an S14 240, you need a MAFs for an S14, and so on and so forth. If you want to run a different sensor than what the car came with, then you need a retune.
