AZ89two4Tsx »
https://forums.nicoclub.com/az89two4tsx-u91596.html
Thu Oct 06, 2011 9:56 pm
If you have S14 seatbelts, you are set. The only modifications you need to do to make them fit are:
Drill a hole in the b-pillar panel for the bolt.
Notch the panel underneath it as shown in the last picture above ^ so the belt can slide through.
Those are the only mods you need to do as far as getting them to fit. You should be able to use your hardware as well. The only other work involves removing the old automatic belt system, which includes the rails, belts, and the control module that is underneath the center console.
