chicos240 »
https://forums.nicoclub.com/chicos240-u20799.html
Mon May 07, 2007 2:48 pm
I feel like an idiot, but I thank you for your help...Car: s14 1995Engine: Sr20det S14Turbo:StockFuel Pump: WalbroOk, so I purchased thisBut the arrows are misleading.. helpIf i Blow in the bottom nipple on the fitting with the knob its hard to blow until I turn the knob to give more boost, the valve opens hence making it easier Now the little tee, If I blow in the nipple that is behind the arrow, its hard to blow, the other two nipples are whores.So how should my vacuum tubes be set?
