a_ahmed wrote:This may be a stupid question but I always believed (internet hearsay) as some have already stated 'does anything go wrong if you relocate it'.
I actually have an NA KA and I was thinking of doing this and running a shorter ram with a 3" filter.
Ive had the run of the mill ebay intake injen knock off for quite some time... and i even got an injen cai for a while. I didnt notice too much power increase if not decrease from running the CAI (butt dyno).
I was thinking to myself... 1) so many pipe bends... doesnt air not like so many bends? Bad for performance anyways? --> hence shortening - better? 2) the run of the mills intakes aaaalll cross the radiator.... the aluminum air intake pipe itself is BURNING hot from the heat from the radiator... pretty much defeating any CAI or what have you...
So this leads me to... is this a good idea, since i have a tiny bralleauto racing battery and will be relocating to inside the car anyways.... that will leave the old battery spot open for a short ram of sorts right there away from the radiator... and the maf just being there. Good idea? Bad idea? Id like to know.... NA KA...
This guy was on the verge of answering your question preemptively.
Chingon wrote:I was gonna write this whole paragraph on the effects of laminar vs turbulent flow in a MAF but 'tis a turbo, so there really is no point I think.
Think about it like this. Laminar flow is when a fluid/gas is flowing in a smooth, uninterrupted way.
With the factory intake, the air has time to smooth out after being disturbed by the filter. This laminar airflow helps to feed more air into the intake plenum. This is why generally speaking OEM cars have a longer intake. A quality aftermarket intake will open the pipe up, and smooth any bends.
With a short ram intake there is less time for airflow to smooth out, leading to turbulence at the throttle body, which decreases the actual volume of air entering the intake.
There is also a second problem, again dealing with turbulence. Every time you open or close the throttle you upset the air flowing through the intake. The longer pipe helps to isolate the MAFS from these disruptions. Lifting throttle with a very short pipe can cause air to back up past the MAFS, this leads to stuttering, and stalling. This is a common problem among the focus crowd, and Ive felt it first hand, and it takes exceptional tuning to eliminate.
That being said, Ive never tried running a short ram on an S chassis. In my experience the reason short rams have gained popularity has more to do with sound, than actual power production.
