KPotter wrote:I thought it would be just putting color together but it doesnt work right... I have (Black,White,Black and white) wires. along with the bare ground wire... but the bare ground wire is missing from the MAF side... Do I just reconnect them to their same colors and run the bare ground to a ground on the car? I cant find a wireing diagram anywhere... Thanks for your help..
Sorry you had to wait so long - usually one of the guys with easy access to wiring diagrams will post a pic. The connector only uses 3 of the 4 pins, so you should be able to put it back just as you've suggested. I don't believe the ground wire goes to the MAF. But ... where's the connector - still attached to the MAF side or the harness side? Which side of the connector was cut? I can't recall offhand - does the ground connect to the harness side of the connector?
As I said, the MAF side only uses 3 of the 4 pins. I know that for a fact.
