M56 lag on take off
DredM56
Car: 2011 Infiniti M56 2004 Subaru Wrx STi
That doesn't necessarily mean anything to me I've talked to plenty that don't know a lot about the cars they work on. The are just following directions to remove and replace parts. Doesn't mean you know all the engineering behind the car.
You can see it in action in the snow easiest. If you baby around a corner but are going slightly too fast you'll understeer like crazy the car just plows.
Gas it a turn the wheel a bit more the front holds its line much better and the tail steps out and is very controllable.
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
"Just following directions to remove and replace parts."
True statement. If they don't find a code and there is no visible wear, they can't fix anything.
Ilya
Except, based on his posts, we know that isn't just the case. Anyway...let's get back to trying to figure out why this car is such a pig sometimes :).
DFW2011M56S
Car: 2011 M56S
Ilya wrote:Except, based on his posts, we know that isn't just the case. Anyway...let's get back to trying to figure out why this car is such a pig sometimes :).
Intake Air and Oil Temps plain and simple. When either one gets elevated my car turns into a complete utter pig.
ProverbPsalms
Car: 2006 M35x - Graphite/Black, Journey, Tech
2011 M56x - Black/Java - Deluxe Touring, Premium, Tech
I have this problem myself, I did not do the timing chain recall as of yet, it appears many have had some issues after it got done, so I will hold off until I read up on it more a bit, but it seems that people have had some luck with the ECU Re-learn, I will try that and see how it goes...
