EdBwoy wrote: ↑Wed Oct 07, 2020 6:10 amIf you can address not only the differential, but also switch the axles to a more conventional bolted flange design, that would be money.
There are a million different things I'd rather do than go back under there wrangling a differential while massaging the axles in - and this was being done on jackstands.
Good luck on the project!
madmanpauly wrote: ↑Wed Oct 07, 2020 9:43 amGreat video! I saw this on the FB page and am eagerly anticipating Part 2. Don't forget to check the improved zero to sixty times!
ibc wrote: ↑Thu Oct 08, 2020 8:33 amCool video. I am also looking forward to part 2. :-) Seems like such a simple difference. Would a thick steel DIY adapter plate work out? Bolt the plate onto G37 differential, then bolt the plate to M56 body.
BTW, what's the reason for the swap? Did the M56 diff break somehow?
The PPE exhaust interests me a lot. But PPE web site doesn't list any M56 exhaust, so was that a custom job or a mistaken reference?
What about offset poly bushings? You could try getting the metal core and pour your own.ken in az wrote: ↑Thu Oct 08, 2020 10:23 amNothing broken, installing for performancean adaptor plate is a good idea but I have a different plan using solid diff bushings instead but i haven't worked out the details yet.
For the PPE Engineering Exhaust, I know they are working diligently to get it up on their site, but with everything right now, it's taking longer than expected. If you call or email them I'm sure they will get you an updated timeline.
Yoda's Master wrote: ↑Tue Oct 13, 2020 2:19 amNice!
Did you use these and just enlarge two holes?
https://www.z1motorsports.com/z1-produc ... 10357.html
Interesting about the Q50/60 Diff and I think you're right. And I like the ratio better at 2.9 than the 3.356 - Yoda can you check to see what model comes with VLSD?Yoda's Master wrote: ↑Sat Feb 27, 2021 9:12 pmNow that you got it working, you should install the Z1 subframe collars to stiffen up your rear end. Our subframe is the same as the q50/60 so it should fit without any issues.
https://www.z1motorsports.com/z1-produc ... 15430.html
TBH, I think the Z1 built q50/60 LSD diff would have been a direct fit.
it is the same frame. same part numberBonkle wrote: ↑Sun Sep 18, 2022 1:27 amHas anybody found out if q50/q60 diffs are a direct fit? I'm aware that the subframe is basically the same. Looking at the diffs compared to a M/Q70 diff, they look like the exact same dimensionally. I agree with Yoda about the bushing, but I really want to know if this has been confirmed or not.
Thanks for confirming really quickly, I planned on getting the z1 built diff and just dropping it in. Hope it works out.Yoda's Master wrote: ↑Sun Sep 18, 2022 1:37 amit is the same frame. same part numberBonkle wrote: ↑Sun Sep 18, 2022 1:27 amHas anybody found out if q50/q60 diffs are a direct fit? I'm aware that the subframe is basically the same. Looking at the diffs compared to a M/Q70 diff, they look like the exact same dimensionally. I agree with Yoda about the bushing, but I really want to know if this has been confirmed or not.
It's gonna be a few months, but I'll be sure to post updates here, maybe make a new thread. I definitely won't be sticking with the stock open diff, that's for sure. If it doesn't work, I hope I can sell the z1 diff easily lol.
You might as well install all poly bushings while you're at it. Car feels so much better even with an open diff.
