M56 Rear Subframe Bushing Replacement ***WARNING. IMAGE INTENSIVE***
Yoda's Master
Car: 2012 M56
2009 370z
WARNING! You're doing this at you're own risk. I'm not responsible for anything that happens to you or your car. Also, disconnect your battery before you start!
For those who have shot subframe and/or diff bushings and/or anyone who just wants to upgrade their bushings then you've found the right post.
First off, there's no direct fit aftermarket solution so be prepared to do some extra work.
I ordered the following. If you use a different brand, then you might need to make further adjustments.
Subframe Bushing: Prothane 14-103 https://www.amazon.com/gp/product/B00BU7XV9Y subframe bushing kit for the 350z/370z.
Rear Diff Front Bushing: Nolathane REV200.0016 https://www.amazon.com/gp/product/B06XY6CZ13 Front Rear Diff Mount Bushing for the 350z/370z.
Rear Diff Rear Bushing DIY 80A HP Liquid Poly https://www.suspension.com/diymmi
Poly KY Jelly: Energy Suspension 9.11104 https://www.amazon.com/gp/product/B000MW5SJ4
1/8" UHMW Plastic Sheet https://www.amazon.com/gp/product/B0070ZAR8I
3/16" UHMW Plastic Sheet https://www.amazon.com/gp/product/B000ILJZE8
1/2" Split Ring Lock Washer (2 ea) from Home Depot
Wheel Bearing Grease
Optional parts to install:
Your choice of Q50 Rear Camber Kit
SPL Rear Lockout Kit
SPL Z33/Z34 Rear Control Arm Bushing (REQUIRES MODIFICATION OF YOUR EXISTING CONTROL ARM)
OEM Parts to order:
55269-AG00E (12 ea) Control Arm Nuts
54588-1CA0A (4 ea) Camber Arm Nuts
08918-6401A (2 ea) Parking Cable Nuts
37120-AH00A (3 ea) Drive Shaft Bolts
37121-JK20B (3 ea) Drive Shaft Washers
37171-AL60A (3 ea) Drive Shaft Nuts
08918-3401A (2 ea) Near CAT Back Exhaust Flange Nuts
20692-8H30A (1 ea) Near CAT Back Exhaust Flange Gasket
40037-1CA0A (2 ea) Axle Nut Washers
00921-5402A (2 ea) Axle Nut Cotter Pins
Optional:
11298-8H303 (2 ea) Rear Shock to Knuckle Bolts (Mine were bent)
08921-3252A (2 ea) Rear Upper Control Arm Ball Joint Cotter Pin.
01225-00062 (2 ea) Drive Shaft Intermediate Nuts
Tools:
Medium sized Amazon Box
Zip ties
Socket and Wrench sets (Mostly 10, 12, 14, 16, 17, 18, 19, 21 mm)
Multiple jack stands
Multiple traditional jacks
transmission jack
Dolly
Impact wrench
32mm Axle Nut Socket
Flat head screw drivers
Dykes
Pliers
Sharpie
Reciprocate Saw
FIRE!!!
Cleaning Tools/Supplies
Now the fun begins :cry:
WARNING! Disconnect your battery before you start! Not my fault if you fry the wheel sensors.
I put the front on ramps and lifted the rear to get it leveled and removed the wheels.
Remove the Calipers and tie them out of the way.
Remove the Axle Nuts. Yours will not be the same setup as mine.
Unbolt the Shock Bolts. Mine were bent/curved over the years so I ordered new Bolts. (11298-8H303)
Unbolt and remove your Mufflers. These Nuts were tight. Order extra Nuts if you round them (08918-3401A)
Disconnect both Wheel Sensor Wires and pop the clip off the Subframe.
Devil Exhaust Nuts. Replace even if you remove them intact. (08918-3401A)
Remove the mid-section and the heat shields.
Mark your Camber and Toe Bolts so you know how realign them afterwards. Do not mix them up when you remove them later.
Mark your Drive Shaft and remove the fasteners.
I took this off because i thought I had to in order to separate the Drive Shaft from the Diff, but you don't have to since it'll come apart as you're lowering the Subframe. Make sure you put the Amazon Box below the Drive Shaft if you do take this apart! Reinstall the Nuts after dropping the Drive Shaft and buy the optional Nuts if you do take it apart. (01225-00062)
Rest Drive Shaft on Amazon box.
I took off the Parking Brake cable here instead of taking the Parking Brakes apart.
Remove the two diagonal braces the doesn't really have a purpose.
Install transmission jack and start unbolting your Subframe.
Drop the phat rear end.
Yoda's Master
Car: 2012 M56
2009 370z
Slide it out.
Recommend you take off both discs since they are heavy AF before transmission it to the dolly.
Put jack stands under the Axles and remove the Knuckle and Control Arms.
Remove the Speed Sensor Wires from the Subframe and pop out the vent tube.
Unbolt the Diff and remove the Subframe.
Tiki torches. Watch out, if you have unpopped silicon filled sacs, then they'll explode and spray out when the rubber burns away.
Don't burn this! Go buy a new Subframe if you do.
Use a reciprocate saw, cut to grooves along the frame side and chisel out the bushing shell.
Do it to all four corners, Smooth out your gouges with a rotary tool and give it some black chassis paint
Clean the surface rust, paint the bare steel surfaces, pop those silicone sacs, and wash it out. I trimmed the rubber flap from both sides. Make sure you hold something in front of it unless you want a face full of silicone.
I forgot to take a picture, but I covered one side with packing tape and bolted a backing to plug one side and level the other side to pour the poly.
Prep your poly and pour it in and let it dry. WARNING. Don't start this unless you're ready. You only have 15 mins to pour.
Pour some out on the side so you can check when it's dry enough to handle. Remove the backing and this is why I trimmed the flap on both ends.
Now let it cure for 7 days.
Prep the Rear Rear Bushing. Make a 3/16" spacer and a 1/8" spacer. I used a 3-1/8", 3-3/4", and 1-1/4" hole saw to make these out the the UHMW sheets. I originally used aluminum, but changed it afterwards.
Make a 3/16" spacer for the Rear Front Bushing. I didn't want to buy another hole saw so I used the 3-1/8" and trimmed it down with a jigsaw.
Bust out the KY :chuckle:
Yoda's Master
Car: 2012 M56
2009 370z
Apply to all surfaces and press in the parts and use zipties to keep them together.
Subframe is now complete! Now lets do the Diff front bushings.
Tilt the diff up, hammer out the bushing, and light em up.
Now use a wire wheel and clean off all the remaining rubber that didn't burn off so you end up with something like this for both bushings.
Prep the Bushings. And make two more UHMW 3/16" spacers. I used a 2" hole saw and drilled out the center to a little bit bigger than 7/8". The thicker poly will feel loose, but will firm up once everything is installed. The 1/2" split ring lock washer is installed at the thinner poly.
Pound the bushing shells back into the Diff and assemble the bushings. Don't forget the KY :chuckle:
Reassemble in reverse order and take reinstall the Subframe.
Make sure you torque the aft Diff Stud before reinstalling the Subframe into the car.
Clean off the mounting surfaces to the best of your ability. You don't want to trap debris between the bushings and the frame.
Reinstall the Subframe.
Tighten them up. Yes, I realized I reinstalled the rotor on the wrong side :facepalm:
Reinstall everything and take her out for a spin.
Ilya
Great stuff man!
Yoda's Master
Car: 2012 M56
2009 370z
Thanks. The car drives so much better now. I used to have some weird bouncing s***, but no more.
Next will be my BC coilovers. Just waiting for the law here to change so I don't have to do another bs vehicle inspection.
Larz
Car: 2019 Q70-L RWD
First allow me to say "Wow, just Wow!". Probably the most photos ever in a DIY and it needed it, too! Well done! Oh, and when you gave that bastard bolt the finger? I think we all shared that emotion. Cheers!
Yoda's Master
Car: 2012 M56
2009 370z
There's finally an aftermarket solution to the differential bushing!
I think my way is better.
https://www.z1motorsports.com/z1-produc ... 34730.html
Yes, I know it says Q50, but the Q50 uses the M37/M56/Q70 Rear subframe.
I'm not sure if the front bushing will fit or not.
I think the rear diff brace might fit.
https://www.z1motorsports.com/z1-produc ... edTogether
Ilya
Nice!
austin713
Car: 2011 M37
mine popped a long time ago and i can only imagine the loss of torque being transferred to the wheels from all that flex. looking on infinitiparts the rear subframe says it fits M37 Q50 Q60 Q70. i really might have to give it a shot. i just wonder how much more driveline vibrations can be felt being hardmounted to the subframe like that.
Yoda's Master
Car: 2012 M56
2009 370z
austin713 wrote:
Tue Sep 26, 2023 11:57 am
None. It's not hard mounted unless you use solid bushings
I guess this thread isn't image intensive anymore since they all died
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Yoda's Master wrote:
Tue Sep 26, 2023 3:52 pm
If you still have the originals, photoshop them to under a meg each and send them to Rogue or AZ, I'm sure they can reinsert them as attachments. This was a great thread, it's a crying shame if it's lost. The beauty of attachments is that they're forever, not dependent on a cloud host. Yes, you lose some detail because of the size limits, but they'll be there for posterity.
drewalbers22
Car: 2015 Infiniti Q70 S 5.6
Thu Sep 08, 2022 1:43 am
By the way,
Q50 Diff brace will not fit the 2015 5.6 Q70S as the 5.6 has a different differential, I already tried lol. It has the r208 I believe.
The mounting holes are ever so slightly off, and it's made of stainless steel so apparently welding is not possible.
Are you 100% positive the q50 diff bushing will fit the rear on a 5.6?
Yoda's Master
Car: 2012 M56
2009 370z
drewalbers22 wrote:
Fri Sep 13, 2024 11:31 am
By the way,
I kind of put it up against the diff and it might be able to fit with some modifications, but I'm saving it for when I have enough money to do a q50 LSD diff and axle swap.
Yes I'm positive it will fit since the q50 subframe is the same part number as the m56. I didn't go that route because it wasn't developed when I made this post and I'm glad it wasn't since the z1 diff bushing comes with a chance of smashing the subframe during installation.
Ilya
Without the images, how hard was this job? Someone on FB thinks mine is leaking after I shared the following image (towards the rear of the parking spot where I park my car)...is this something a basic DIY'er can do or is it best to buy the rear bushing and take it to a shop? Any other bushings I should consider changing at 145kmi?
Yoda's Master
Car: 2012 M56
2009 370z
Ilya wrote:
Sat May 03, 2025 4:45 pm
Try take a look at your diff to see if it shat itself. It'll be pretty evident if you see a poop stain running down the diff bushing.
and yes :worthless:
if there's a way i can edit them, then i can redo the pictures.
Back to your original question...yes it is DIY-able, but you'll need to consider if you have the motivation, skills, tools, time, and another form of transport.
I changed every single bushing on the subframe, diff, and control arms. car feels great! No extra vibrations!
I wouldn't buy the Z1 bushing. It's a complete waste of money and you might damage your subframe if you're not careful installing.
You could also cheap out and do this:
1 year review
Ilya
If you want to send me the new image links, in the right order, I can update the posts.
Yeah my issue is I don't know if I have all of the tools or strength to press this thing out and back in. I'd love to replace all bushings too, as it's probably time, but my tool set is mostly for things like brakes and oil changes lol.
But thank you for the recommendation...sounds like avoid Z1 and go OEM is the best way to go.
Yoda's Master
Car: 2012 M56
2009 370z
Ilya wrote:
Sun May 04, 2025 5:31 am
Give me some time ti find the right order.
I didn't go oem. my bushing had dry rubber cracks when i did my subframe bushings so i took some extra time to pop it and fill the oem bushing with poly while i had the subframe off the car
Ilya
Confirmed my mount is shot. I might give that brace a try and do the $20 fix to fill it and see if it works.
Ilya
Thank you, Yoda, for rehosting the pictures. The thread is back, baby!
Ilya
I did the cheap fix for the rear subframe bushing and it seems to have worked. I pumped that thing chock full of epoxy, waited 30 min and thing was hard as a rock lol.
Yoda's Master
Car: 2012 M56
2009 370z
Haha. Yea, it's the cheaper way
Ilya
I'm also going to order the Q50/Q60 rear brace (there has been some concern on the FB group that the brace won't fit - and Z1 can't confirm it either) because comparing their image to my rear diff, it looks exactly the same. Need to order spare bolts too as mine look horrific.
Ilya
I just realized I never updated this thread - the brace didn't work for the car and I returned it paying a restocking fee IIRC.
MarseilleExpress
Car: 2012 Infiniti M56X
2020 Infiniti Q50 Red Sport
2003 BMW 530i
2000 BMW 740i
Ilya wrote:
Sun May 31, 2026 8:51 pm
If you don't mind me asking, what made it not fit? I noticed that when I compared the Q50 differential and M56X differential that the M's back plate looks a little different than the Q50's. I did a little rough test fit of the Z1 differential brace on my M56X without unbolting anything and it looked like it can fit.
Ilya
MarseilleExpress wrote:
Wed Jun 17, 2026 12:06 pm
IIRC, it's been months, but the bottom mounts were off by like half an inch or so. Visually looked perfect, but when lined up it was just a bit off.
