Honestly I can't tell you anything about the tune - I couldn't even get answers from the tuner. I couldn't even get the freakin tune file. I am more than dissatisfied with the way things went down that day which is why I said I will be going to a different tuner this next time.DeanM45 wrote:There is too much emphasis on "peak" numbers. Can you post up the graphs of before and after the tune?
Did the tuner remove the throttle lag (stock, WOT under 10 mph or so still only gives abut 60% opening) --- UpRev can remove that.
What A/F ratio did the tuner calibrate to?
How many miles are on your car and when did you last replace the plugs?
What intake and what exhaust (mufflers, mid-pipe, Y-pipe) are you using?
I have not put my M on a dyno but I do a lot of monitoring and my UpRev tune (done by Seymore4 here on the forum) along with my supporting mods dropped my 0-60 time (when I have traction) to ~4.5 seconds. Plus a whole host of other benefits.
Dude 3" pipes!!!M4point5 wrote:Sure boosted is easier to achieve the numbers - thats not the point. I am trying to justify $750 for 10hp...trying to gauge where everyone stands and see if my tuner just didnt give a s*** or what. I mean, he tuned the car in 3 pulls....
Aside from that, theres no point in a 3 inch exhaust system when the restriction in the stock header design isnt going to allow for full use of it. There is basically zero aftermarket support for these cars which is sad...custom header shop here wants $400 PER runner on a set of headers. No thanks, not building this to race.
What tune are you running and who did it?msvara wrote:Dude 3" pipes!!!M4point5 wrote:Sure boosted is easier to achieve the numbers - thats not the point. I am trying to justify $750 for 10hp...trying to gauge where everyone stands and see if my tuner just didnt give a s*** or what. I mean, he tuned the car in 3 pulls....
Let me tell you a story that will hopefully make you feel better. A friend of a friend of a cousins nephews friends brothers mother... Had a porche cayenne non-turbo spent $6000 on a new exhaust and intake and an ecu tune and gained 6hp over stock. The cayenne was already pretty tweaked from factory. Similarly I believe the m45 is pretty tweaked from factory. That said you mentioned the tuner you used finished in 3 pulls?! He definitely cut corners. For my experience we filled up the car and jumped on the highway. 4 pulls just to obtain readings then he had me do 4 pulls while he played with the ignition timing. 4 more while he played with the cam timing then 3 to check them together. 2 hours later I had my tweaks done.
That said has anyone heard of their cars going into limp mode often while driving normally through the city? No codes but initially the tuner noticed my car doing that often due to excessive knock. I always used grade 91 or higher octane and my mods are ported polished lower intake plenum. Z tube and skunk2 spacer. I'm not burning coolant cause the level in the bottle has been the same since I flushed it 2 years ago. I do burn about a litre of oil between changes. I'm going to add a can of seafoam next fillup and next oil change switch to 15-w50.
I may as well just write it all out now. "The tune" took 7 freaking hours...my appointment was at 11. I show up at 1045, "our tuner isn't in right now - he will be back around 12:30." I leave the car, come back at 12:30...still not there. I WAIT at the shop and he finally comes at 1:30 and tells me he had to help "a customer" tow his car. Now, this shop has gone through quite a few tuners and can never seem to keep one. To my SURPRISE, the guy who was going to be tuning my car was the SHOP OWNER. Couldn't call me to tell me he would be in late, nothing. That's nearly 3 hours gone now.mexillis wrote:IMO three pulls is not enough. Mine took about 2 hours and from other members it took about the same. There was another member that was tuned at the UpRev main location and had a gain of nothing, hp wise. He had the injen cai and stillen exhaust. The car ran better from what he said and it felt stronger but the dyno graphs were disappointing...def keep us posted on your new mods and if your shop will produce more parts and for how much.
WOW! I would not go within a mile of that "shop"!M4point5 wrote:I may as well just write it all out now. "The tune" took 7 freaking hours...my appointment was at 11. I show up at 1045, "our tuner isn't in right now - he will be back around 12:30." I leave the car, come back at 12:30...still not there. I WAIT at the shop and he finally comes at 1:30 and tells me he had to help "a customer" tow his car. Now, this shop has gone through quite a few tuners and can never seem to keep one. To my SURPRISE, the guy who was going to be tuning my car was the SHOP OWNER. Couldn't call me to tell me he would be in late, nothing. That's nearly 3 hours gone now.mexillis wrote:IMO three pulls is not enough. Mine took about 2 hours and from other members it took about the same. There was another member that was tuned at the UpRev main location and had a gain of nothing, hp wise. He had the injen cai and stillen exhaust. The car ran better from what he said and it felt stronger but the dyno graphs were disappointing...def keep us posted on your new mods and if your shop will produce more parts and for how much.
I wait ANOTHER 30 minutes for them to push cars around in the shop so they can get me onto the dyno. Strap it down, blah blah. Now he does one base pull and turns the car off. Fiddles around on his laptop for 30-45 minutes. Does another pull then turns the car off. Comes out and tells me the car is too heat soaked to run it anymore so he is going to go get lunch and try again in 45 minutes.
45 minutes goes by and he's still gone....finally after an hour, he comes back and says the engine is still "really hot" so he can't do another pull. I tell him to do it anyways and let's get this finished because I have been there all day. He waits around 30 more minutes then finally does another pull, plays on the laptop then says the tune is done. After I get the keys, I try to get the tune file - no sorry we don't do that we don't want people stealing our tunes. OK - that did it...$750 for jack s*** basically...I made it VERY clear I wouldn't be back to his shop.
And that is my experience...I will be going where I SHOULD have gone in the first place (shop that specializes in Nissan)
Oh trust me, I will not. I have NEVER experienced such poor service at a shop. The other shop I will be going to is pretty good - they were a month out for tune which is why I gave the other shop a try. Even if I don't gain any power, at least I will know exactly what is done to the car and that it is done RIGHT.DeanM45 wrote: WOW! I would not go within a mile of that "shop"!
CPJ LB wrote:it's fine that you're doing the tune Ilyakol...like you said, the short list of mods you have will be fine without a dyno.
in addition to the eco map, my tuner has it set to where if I were to floor the gas or get on it...the sport tune automatically kicks in -- that was a bonus feature. (for emergency purposes like getting out of harms way, etc)
I keep my setting in 'sport' for the majority of time...but also in eco setting.
my mpg has ranged from 15 to 19mpgs (depending on the type of driving and setting)
as far as power added from the tune, yes...it's provided, but it also depends on the supporting mods...here is a breakdown of my prior dynos and I've had the Uprev for over a year.
FACTORY RATED 06 M35sport at the flywheel = HP: 280 TQ: 270 (which is rated very low at the wheels)
Initial Uprev
3/22/11 - Baseline run 91 octane
NEAR STOCK (K&N drop in, stock mufflers w/xpipe and 2.25"piping from cats) =
power at the wheels:
whp: 229 @ 5953 A/F: 13.79
Tq: 228 @ 4938
3/22/11 - Adding TUNE: UPREV w/Osiris
whp: 252 @ 5952 A/F: 12.98
Tq: 238 @ 4767
4/18/11 - 91 octane(5/16 MD plenum spacer, K&N drop in, z tube, 2.25" dual exhaust piping from cats - xpipe, high flow resonators - to stock mufflers)
whp: 265 @ 6300
Tq: 245 @ 4745
11/15/11 - 91 octane
(5/16 MD plenum spacer, MD MREV2, MD Isothermal gasket, K&N drop in, z tube, G35 Ypipe,Megan exhaust 2.5"mid pipes & axle backs, NGK spark plugs)
power at the wheels
whp: 282 @ 6408
Tq: 255 @ 4693
*Test run for lower end tq: 270 @ 2691 rpm
I now have HFC's and will put on the Motordyne xyz pipe to get a test run on numbers, but from my butt dyno, since adding the HFC's I've felt a huge difference in overall power...the car definately pulls hard.
Driving in manual mode allows you to use the entire powerband...I don't go past 7000rpm to prevent wear and tear of the rods, springs, etc(as you can see the majority of my HP is at approx 6500rpm's)...those that have built motors don't have to worry about going "too" high in the rpms....
the best thing I enjoy is the drivability of the car..."its more fun to drive"....
??? No one said anything about copy and pasting.06M4.5 wrote:I have seen it with my own eyes when Robert got his Uprev tune done and then I got my M done at the same shop with the same dyno. Both cars ran different. This is not paste & copy people.
Freddie i had two choices Long Island or New Jersey, I chose JDS motoring NJ because it was closer. Im glad that we went there and got our cars tuned. We watched everything from the start to the end. The guy ran my car at least 10 times on the dyno. Its nice to see what they do with your car, when you paying $600.06M4.5 wrote:I agree and still rather do it in a safe manner.
Getting a good tuner isn't easy. Thats why I thank Robert for finding the tuner we went too.
