NightWatch wrote:OK.... I printed off this entire thread and went to my Infiniti shop and sat down with the Sr. Tech and showed him what had been done. I was trying to get an estimate out of him for doing the same install on my 2008 M35 Sport. I would provide all the parts, Infiniti would provide the labor. He said he'd seen it done on one other M, but I would also need to swap out my 19" wheels for 20" because there wouldn't be enough clearance for the Calipers in the front. Is this true Steve?
M45Owner wrote:I don't believe it is entirely true. If you use 20mm spacers (I believe somone else said that would probably be the minimum) the BBK should clear on stock 19's. I don't have a bbk kit but I do have 25mm spacers lowered on eibachs with the stock 19's and I think it looks great. If you aren't going to lower your M then I believe 20mm spacers will look better.
Yup, I installed mine with the 20mm spacer on the stock 19's. They'd even fit on certain 18" wheels too with the correct clearance spec. There are also a few Rays 350Z and G35 wheels that would work too.
