Larz »
https://forums.nicoclub.com/larz-u216291.html
Mon Nov 02, 2015 10:07 am
I had the following done earlier this year. 2009 M35, HR engine, RWD, 7-spd gear box. Should be somewhat close to the cost for the 37s and 56s to change the various fluids.
I bought my 09 last Oct with under 30k miles, but it's 6 years old and I could not verify if any fluids had ever been changed so I considered them to also be 6 years old and due for change.
Transmission (actual complete flush with removal of pan(s), clean magnets, inspect for filings, etc.)
Flush, exchange, inspect:
90.00 labor
129.00 fluid 10 qts Matic-S MTS00P
15.00 trans conditioner L4100
14.13 waste and shop supplies
_____________________________
$ 248.13 total
Rear Diff fluid:
113.70 labor
30.00 2 qts limited slip oil
8.62 waste and shop supplies
______________________________
152.32 total
Brake Fluid Exchange:
118.95 labour and flush
19.95 1qt DOT-3 fluid
8.34 waste and shop supplies
147.24 total
Coolant Flush:
95.95 labor and flush
24.95 long-life anti-freeze AF000P
7.20 waste and shop supplies
$127.15 total
Brakemotive:
90.00 front axle replace rotors and pads
90.00 rear axle replace rotors and pads
____________________________________
$180.00 total
Complete inspection:
95.99
________________________________________________
$95.99 total
Total for today's services:
950.83
-95.99 (inspection service waived for customer)
$854.84
*** I had a cow after learning they charged $180 just to install the brakemotive kit after I was charged for a brake fluid exchange with labor already included ! So my service guy (Brian) made them waive the cost for the inspection which, by the by, came out absolutely perfect.
Some will say: Mate, they took you for a ride. You could do all of this yourself for a pittance compared to these prices!
I say, consider this:
1) who warranties work that you did yourself and if you need documentation it was done, how do you prove it?
2) I will wash my own car, change my own oil and filter, engine air filters, seat and cabin filters, bulbs etc. But nothing
that can leave me stranded or endanger precious cargo (me !! and others) should be treated cheaply.
