For example: At 30,000 miles, the "Optional Premium Upgrade" reads:...."Replace Automatic Transmission Fluid" 3, and the 3 footnote reads, "Except models with 7 speed automatic transmissions." ......... Footnote #3 leaves me questioning if the fluid is changed, or not?tollboothwilley wrote:I think all G37 from 2009+ have the 7AT or else the 6MT. maybe you were reading in the 6MT section and not the AUTO trans section.
i never knew this. thats pretty cool.Fezzik wrote:The 7 speed automatics are not serviceable In other words you can not change the fuild. Its designed to last for longer than the transmission
Wow. Given that we have word from an Infiniti Master Tech that it's a sealed unit, I'd call Infiniti Customer Affairs if my dealer said I needed the fluid changed.cjs37xs wrote:So, my dealer is trying to screw me? (shocking, I know...)
I was just advised to have the transmission flushed and changed. Didn't get it done, as I was only getting an oil change.
Thats an interesting question to me too.tollboothwilley wrote:No dipstick for you guys huh? Thats very interesting. How is the trans fluid supposed to not degrade?
cobravin wrote:i have a 2009 g37x 7at and have changed the fluid myself, its true it is a sealed unit but it obviously can be serviced
there is indeed a drain and fill port on the pan, nissan wouldnt sell me the charging pipe or whatever its called but you can easily make something up like i did, but your going to need the consult 3 to check the level and bring it up to temp to get the correct level.
That dealer is a thief. NONE of those fluids need replacing at 30K or anywhere close to that. Check your owners manual.crisfer wrote:The dealer told me at 30K that my ATF was dirty/discolored as well as my brake fluid, differential, power steering and my engine coolant was diluted.
I want to keep my car should I change all these fluids and no I cant change myself the only things I can barely do is the in cabin and engine air filters?
Does the auto transmission alert you when it needs service?
If its sealed with no dipstick how did my dealer realize it was dirty/discolored?
Matt, what's up with the goofy indexing on those? For instance the item labled "2011 G37 Sedan Service/Maint. Guide" is actually the 2011 Infinity Warranty Information booklet when you drill into it.audtatious wrote:Service and maintenance guides should be referred to in these cases. All can be found on Infinitig37.com
G37 Coupe Manuals
G37 Sedan Manuals
G37 Convertible Manuals
Cheers.audtatious wrote:That means I probably had too much to drink when I put the pages together
I'll go through them again.
