M37 aftermarket sway bars
parkstr8r
Car: 2018 Infiniti Q70S
2016 Gt-R
2018 Audi Q7
2016 Audi S6 (gone)
My guy can't locate this part...can anyone let me know where to buy it? Rear sway bar only...
thx
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
isn't the part number PN14B for the rear?
rjoe
Car: 2011 M56S
parkstr8r wrote:Rjoe - can i get the part number? My guy can't seem to locate it to order...
This is all the order confirmation had, no specific part numbers from Tanabe.
Make:TANABE Item name:Y51 FUGA Stabilizer/rear 01
Make:TANABE Item name:Y51 FUGA Stabilizer/front 01
Darthswan
Car: 2012 Infiniti M37x
99 Nissan Maxima
Any update? Would really like.
rjoe
Car: 2011 M56S
This is all they gave me: Make:TANABE Item name:Y51 FUGA Stabilizer/front 01 and Make:TANABE Item name:Y51 FUGA Stabilizer/rear 01
Saaax650
Car: Infiniti M37
This is the link below
https://www.nengun.com/tanabe/sustec-stabilizer
The site link posted initially on this thread goes to a Japanese p0rn site -- performance
Shanehsmp
Car: 2006 Infiniti M35x - Sold
2012 Infiniti M56x
2016 Infiniti QX70s
Saaax650 wrote:
Tue May 12, 2020 1:37 pm
Lol, I opened it before I saw this....the wife asked me if Japanese women were my type. I shrugged.
Yoda's Master
Car: 2012 M56
2009 370z
Shanehsmp wrote:
Tue May 12, 2020 1:51 pm
It's actually a Chinese p0rn site, but anyways...the OEM P/N for the rear sways are the same for both the sports M56 & M37 and both the non-sports M56 & M37, but the front sways are different part numbers, that's my the op couldn't get the front to work.
Also the rear OEM sways on M37, M56, Q50, Q60, Q70 are all the same.
Yoda's Master
Car: 2012 M56
2009 370z
I think I know why the M37 front sway wouldn't fit, it hits the oil filter. M56 oil filter is located to the front of the engine, whereas the M37 oil filter is on the passenger side. You need to get a oil filter relocation kit if you want to use the M37 front sway bar.
I could be completely wrong, but that's my best guess.
biggie
Weird this just popped back up. Looking at the rear aftermarket bar I have laying around it looks like the Y51 Tanabe bar, wonder if I should try to swap it out or would I hate it without the matching front one.
biggie
Just saw this from Europe somewhere, don't know anything about them though.
https://www.r-parts-store.com/Hardrace- ... finiti-Q70
EdBwoy
I would like to add to Yoda' s comments. Speaking OEM strictly:
There are 2 options for the rear stabilizer bars
1. 56230-1MA0A. Sport - both V8 & V6
2. 56230-1MA0B. Non-sport - both V8 & V6, which includes AWD
There are 5 options for the front
1. 54610-1MT1A. Sport V8
2. 54610-1MA1A. Non-sport V8
3. 54610-1MT0A. Sport V6
4. 54610-1MA0A. Non-sport V6
5. 54610-1MA0B. AWD for both V8 & V6
For the front, there are 3 diameters - Sport, Non-sport & AWD.
The hybrid with its near perfect F/R weight distribution shares the non-sport rear bar 56230-1MA0B, but the sport model front parts - 54610-1MT0A.
These are some things to be aware of as you buy aftermarket or even used parts, lest your changes end up having an undesirable effect on your handling.
Obviously, if you have a good understanding of chassis & suspension dynamics you can use any combination of sway bars (or make your own) to have a car balanced well enough for whatever you intend to use it for.
Reason: Edited to add part numbers
biggie
EdBwoy wrote:
Wed May 13, 2020 11:24 am
1. Sport - both V8 & V6
2. Non-sport - both V8 & V6
1. Sport V8
2. Non-sport V8
3. Sport V6
4. Non-sport V6
5. AWD for both V8 & V6
The hybrid with its near perfect F/R weight distribution shares the non-sport rear bar, but the sport model front parts.
Know if L model changes anything? Assume it still uses the same AWD or Non-sport stuff.
EdBwoy
The wheelbase doesn't seem to matter. All LWB rears are the non-sport regardless of engine size. The front parts go as expected, V6 long & short share a part #, V8 long & short share theirs.
Obviously, no sport models for the long wheelbase so they only get 3 options for the front.
Although the AWD longbase isn't explicitly called out, I would assume all AWDs use the same stabilizer bar because of the shape & to account for the extra weight on the nose. The AWD bars are usually beefy, but I didn't think to take any measurements when I owned my M56x.
biggie
Anyone have a diameter on the AWD rear sway bar?
I may look at mine and measure. Then see if I want to swap the other bar that I have that I assume is a tanabe.
Yoda's Master
Car: 2012 M56
2009 370z
AWD rear is the same and non-sport rear. P/N 562301MA0B
https://www.discountinfinitiparts.com/o ... 562301ma0b
Hotchkis makes a replacement for the sports rear sway.
https://www.hotchkis.net/product/infini ... 59&sm=4411
biggie
Yoda's Master wrote:
Wed May 13, 2020 10:47 pm
Hotchkis is listed as not MQ70. ?
Yoda's Master
Car: 2012 M56
2009 370z
Yoda's Master
Car: 2012 M56
2009 370z
I know this is old, but i ran across these today.
https://www.hardrace.com/Product_detail ... &MainType=
I have a hotchkis 370z front sway laying around that I can test fit and see if it really fits.
Shanehsmp
2012 Infiniti M56x
2016 Infiniti QX70s
Fri Feb 19, 2021 9:54 pm
This would be cool...here for the results
Yoda's Master
Car: 2012 M56
2009 370z
TL/DR: Doesn't fit. Sort of.
I shouldn't have expected much since the install instructions on that website is in Chinese.
There's 3 issues.
1. The 370z sway is slightly narrower so you'll need aftermarket end links that comes with spacers to fit it properly. Either the SPL or Voodoo13 endlinks would work.
2. This won't fit the M56 because it hits the oil cooler.
3. The 370z has a recess spot for the bushing to squeeze into, but the y51 frame doesn't so the bracket sits about half inch off the frame. If you can find or make a bracket that fits properlty, then this could fit the M37 since it's oil cooler is in a different position..
zae063
Car: 2011 Infiniti M37x
I wonder if the g37x rear and front sway bars would work fine?
