The revup and non-revup are both VQ35 engines...just different variants.azeiler wrote:I was definitely confused about the revup - I forgot the 06 M35 has the VQ motor. Maybe I'll look into something other than the MREV2 since I'd like to squeeze some more hp out of this particular mod. Any suggestions? Back to researching....
No, they have a "short ram" one too. Avoid those...they just suck in hot air from the engine bay. As far as water, I traded out the K&N filter for an AEM dry flow one and put on a material over the top of it that is supposed to repel the water. I wouldn't go through puddles with it, but as far as driving in the rain, I checked the first couple of times and everything was dry. The last time I was in there I also put in a piece of plastic to help direct air flow and also prevent any water from the front from getting to the fiter, just in case.azeiler wrote:I like your idea of wrapping the intake. Do all Ingen intakes go into the fender well? If the air filter is in the fender well, don't you get water in there when it's raining? I guess I'll have to start avoiding the puddles instead of plowing through them like I usually do.
Yes, but you'll need to tell them your mods and send them a saved scan so adjust accordingly. Or have a local tuner do it, if you have one. They have a list on their website of tuners.azeiler wrote:Will the Uprev tune take care of tuning the new intake & exhaust?
Thanks for the enlightenment (although I may be more confused now). So how do I know which motor I have? Are you only going with the MREV2, no spacer?rgb129 wrote:The revup and non-revup are both VQ35 engines...just different variants.
I still think for ~$340 (439 - $100 core refund) the MREV2 is a good deal for the gains. I am going to order one when I can get some more time to work on the car.
I don't suppose you could post a picture of this. Do you remember what material you put over the filter? Did this intake produce a noticable difference (i.e. fun-to-drive factor)?rgb129 wrote:As far as water, I traded out the K&N filter for an AEM dry flow one and put on a material over the top of it that is supposed to repel the water. I wouldn't go through puddles with it, but as far as driving in the rain, I checked the first couple of times and everything was dry. The last time I was in there I also put in a piece of plastic to help direct air flow and also prevent any water from the front from getting to the fiter, just in case.
You have the non-revup. I am going to go with just the MREV2.azeiler wrote: Thanks for the enlightenment (although I may be more confused now). So how do I know which motor I have? Are you only going with the MREV2, no spacer?
I will the next time I need to get in there. I will post a picture of the wrapped upper part of the intake. The filter cover is made by Outerwears. Google them and you'll see what it is. The butt dyno didn't really feel it. It changes the sound...there is more of the growl from under the hood.azeiler wrote:I don't suppose you could post a picture of this. Do you remember what material you put over the filter? Did this intake produce a noticable difference (i.e. fun-to-drive factor)?
I went the custom route on the exhaust. I cut out the stock Y and put in a magnaflow X-pipe, 2.5 inch pipe, Vibrant resonators, and magnaflow mufflers. I am seriously considering putting on G headers with high flow cats. There is plenty of room to do so when I looked at it while the car was on the lift for the coilovers.azeiler wrote:What about exhaust? Stillen says "this is also one of those vehicles where a full catback adds nothing but expense and shipping weight." What about headers? High flow cat(s)? Larger pipes? I see the G guys getting all this stuff. Is this available for M35's?
I personally would do the MREV2, exhaust, and uprev first. I would go custom on the exhaust and do the whole thing...headers all the way out since you'll be getting the uprev. This will probably put you over the $2k though. One option is to do just part of the exhaust now...from the cats back with an X-pipe. The exhaust made a noticeable difference, especially at highway speeds. I also did my own grounding kit which made a difference in throttle response and probably some more power. It was cheap to due...just the cost of the wire and the ends.azeiler wrote:I have about $2K to spend and want to get the most bang for the buck. Feel free to make suggestions.
You do not want to go strait back. Maybe a built race car, but not a street car. Do some googling on strait vs X/H/etc and you'll find people on both sides, but look at the science behind it and less at the people pulling sh*it out of their a$$. It is all about the pulses.azeiler wrote:rbj129 - Thanks for all the info and pics!! I think I'll start with the MREV2 and grounding kit. From there I'll have to decide what I'm going to do (or willing to live with) about the exhaust.
If you already got rid of the y-pipe, why not go straight back? Why the x-pipe?
Doesn't the magnaflow make your M louder? I don't want to necessarily make mine louder.
azeiler wrote:2006 Infiniti M35 – No mods yet – Live in S Florida
I want to increase hp as much as possible as a naturally aspirated engine and without going into the motor. If I use the hp figures on Stillen's site plus others I’ve seen elsewhere I get the following increases:
• Stillen Exhaust +15hp
http://www.stillen.com/product.asp?id=S ... &model=M35
• Stillen Pulleys +10hp
• Cold Air Intake +7hp
• Motordyne MREV2 Plenum & ½” Spacer +20hp
• Uprev tune +10hp
That’s 60+ additional horsepower for around $2,000! That's freaking unbelievable!!! I obviously do not want to spend money on things that will offset each other's hp gains (I think that's called stupidity).
mexillis wrote:For exhaust def. get a custom one, u pay less and get more HP than stillen. They only tell you it's not beneficial because they want you to buy their product.
I had read about hp stacking after I posted. = (fiveliterbeater wrote:after reading everyone's thread im surprised no one stepped in here to correct this common, yet undisclosed term, frequently know as "horsepower stacking"
each mod by itself will generate a certain amount at the wheels. but combined with other mods, you will not be able to properly generate the advertised HP. a point you made in the end of your thread. and no it's not stupidity. if anything, companies like Stillen are to blame for promoting this b.s. . kinda like Gas companies advertise Premium fuel (91+ octane) as being TOP OF THE LINE fuel and the lower grade gas (87 octane ) to be the crappy inferior fuel.
fuel companies know this and continue to advertise this common misconception. Aftermarket car performance companies are no diffrent.![]()
with all the mods listed above you should see a healthy 30-35 more at the wheels which should translate to about 40-50 more at the crank.
not far off, but not as close as you would think you should be. you are on the right track though.
only thing i claim b.s on is the plenum spacer. 20hp????? gimmie a break. you're lucky to see 5-7 more at the wheels. (which would translate to (10-12 more at the crank)
oh and yes, $2000 for all that isnt too bad....but did you forget to add up labor?
azeiler wrote:I just listened to a bunch of exhausts on youtube. I am going with magnaflow mainly because they didn't seem too loud, especially at idle or light driving. Since this is how I drive when the wife is in the car, I'm ok. Magnaflow has a lot of different cats to pick from, most with the option of 2.5" inlets/outlets. Anyone know anything about these? I'm still not sure if I should go to 2.5" before or after the cats.
They also have one for Nissan/Infiniti that's $840. It's jetted for 35, 70, 100 & 150 hp. That's sweet!!
