IMG_2115 by Bravoval, on Flickr
IMG_2114 by Bravoval, on Flickr
IMG_2110 by Bravoval, on Flickr
IMG_2117 by Bravoval, on Flickr
IMG_2125 by Bravoval, on Flickr
+40 minimum be safer with +42 or +45 stretch tire just a Lil with 265/35/20" another member here has 20x10 +40 275/30/20" tires rub a bit in the front!! 265 gives it the extra clearance by stretching!! I ran 265/35/20 on my 20x10.5 +42 and they were perfect!!!Bravoval wrote:What kind of offset should I use with a 10x20 wheel all the way around? Anyone have any friends that have done this before?
Good Luck with that!! Definately will need mooore stretch on the tires!!Bravoval wrote:Ordering 20x10.5 with 27 offset.
You know I recall a post of your wheels for sale and you noted on there that rear tires had some wear from rubbing??mr_luv wrote:I ran 20x10 +40 with Zero issue. 275/40/20 tires.
Nice choice, I'm ordering Stance SC-6ix 20x10.5 +42 or +45 whichever is available this month... Always been a fan of the Vertini product!! Also front "sport bumper" is hard to find... Good luck!Bravoval wrote:You did. I'm getting the sc5 20x10.5 just looking for the right offset. I can't find that bumper here anywhere locally but I'm going to get this set up done this summer.
The Bodyguard wrote:You know I recall a post of your wheels for sale and you noted on there that rear tires had some wear from rubbing??mr_luv wrote:I ran 20x10 +40 with Zero issue. 275/40/20 tires.
I'll look for the post!!
Here it is:
esm-004-fs-t558451.html
D2 racing coilovers are great!! If you can budget in $900+ labor. I can try and help out with a seller for that price! If your factory struts are old and going out this is a good option... However I have found in my many suspension experiences that eibach is the best way to go!!! Affordable and ride great!! Just my thoughts...Bravoval wrote:Your right! I sell cars and I know a guy over at Infinity! I'm going to just buy the sport bumper new. Thanks for all the advice but a few last request. I was thinking d2 suspension but what kind of coil overs should I get?
you can try to mill 2 or 4mm of the rear of the wheels so they don't stick out.Bravoval wrote:Ok so im in! I just called the a guy here locally and I bought the bumper over the phone brad new. I also just bought the camber kits from eibach. D2 are for sell all over the place but not sure where to buy them from. One last thing I bought the 20x10.5 SC5 for all corners? Does anyone think thats a bad move with the 45 offset? I dont want my wheel to stick out to far?????
My 20x8.5 up front with a +18 offset is actually more aggressive by 2mm than what you're getting. You will be good.Bravoval wrote: One last thing I bought the 20x10.5 SC5 for all corners? Does anyone think thats a bad move with the 45 offset? I dont want my wheel to stick out to far?????
