M35 20x10s all the way around is done!!
Bravoval
Car: M35 Sport.
:dblthumb: I just changed my order for a set of only two wheels at a time. I ordered the Stance SC5 20x10 with a 42 off set. Im going to try them in the front and if they fit Im going to use them up fornt if they don't fit up front they will in the back. :ohno: All the way around is the goal or maybe 20x10.5 in the back. Thank for replying back I changed my order after you sent this. :woot:
06M4.5
Car: 2006 M45
does the 10.5" have more concave than the 10"?
Bravoval
Car: M35 Sport.
Got it!!
Bravoval
Car: M35 Sport.
Ok. I got it and this is what I did I order the 20x10 Stance Sc5 two at a time. My plan is if these will not work up from I'll put them in the back. I also ordered new slotted and drilled rotors to make the wheels stand out. I should be getting the shipment in bye next week. Ill post pick and feed my results on this post. BTW have you heard or know where their might be a good post on the exhaust system setups. Im looking for a deep sound similar to this to go with the look I'm wanting.
http://www.youtube.com/watch?v=pGaEncKMyw4
06M4.5
Car: 2006 M45
Thats not deep at all, just loud.
Start with no mufflers or resonators, just straight pipe.
06M4.5
Car: 2006 M45
or if you gots lots of money:
http://www.youtube.com/watch?v=jWqmlUp3wtE
Bravoval
Car: M35 Sport.
From what I was told about the 10 vs the 10.5 no their is no difference. But between the 9.5 and ten yes. Thus is what the rep at wheelfire said. If the 10 fits the front I'm getting 10.5 for the back so I will find out first hand. As far as being loud maybe your right but I think their still is a deep tone to this.
Bravoval
Car: M35 Sport.
Sounds like a good idea.
06M4.5
Car: 2006 M45
Bravoval wrote:From what I was told about the 10 vs the 10.5 no their is no difference. But between the 9.5 and ten yes. Thus is what the rep at wheelfire said. If the 10 fits the front I'm getting 10.5 for the back so I will find out first hand. As far as being loud maybe your right but I think their still is a deep tone to this.
10x20 with et42 should fit on the front
10.5x20 with et45 will fit the rear but will stick out, it can be fixed with small pull. Camber will also work but will hurt tires if given too much.
you can always try to mill 3mm of the back wheels to make it an et48 if you have the room and it should be flush.
what tire size are you going with?
06M4.5
Car: 2006 M45
here you can see 20x10 with et38 all around:
http://www.freshalloy.com/garage-vehicl ... SPORT.html
Bravoval
Car: M35 Sport.
Nice!
Bravoval
Car: M35 Sport.
:chuckle: Status update, two of my wheel Sc5's will get here tomorrow. I was did some last minute tire shopping online looking for that best deal. Tires are f*** $$ but I came across an add on craigslist for2 Falken 2756/30/r20's and 2 Toyo provys4s 245/35/r20 ALL for 350$ I took a chance based on the pictures and talking with the guy over the phone. I Pay Pal the guy so he wouldn't sell them out from underneath me. I just picked them up about two hours ago.. :mike Bros this guy gave me 5 tires 3 were Toyo4s two where Falkens and as soon as I can find mi iphone cable Ill post the picks!! Sweet f*** deal and pratically new tires!! :woot: Seriously it was christmas in February and I think I left my cable at work so I'll post the add he had and now and some picks tomorrow with the tires and on the Stance Sc5s. Btw any one know if I can retain the TPMS sensor on my m? :yesnod
Bravoval
Car: M35 Sport.
He deleted the post. : (
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Congrats!! Good deal but you didn't mention what size tires you will be using?! :gotme
Also, yes you can retain and reuse your TPMS. Easiest way to do it is be sure to mount (tell the tech) the sensors accordingly to the position from where they were removed from the stock wheels...ie, front left stock rim to front left sc5 rim, front right stock to front right sc5 wheel etc.... Just so their won't be the need to reset or reprogram the sensors! :dblthumb:
Hope you understood that... Good luck!!
Bravoval
Car: M35 Sport.
:gapteeth: Ok so for the front I think I am using 245/35/20 the Proxys and for the back I'm am using 275/30/20. :whistle:
mexillis
Car: M45s
Sounds like a good deal, how much tread is left on them?
The Bodyguard
Bravoval wrote::gapteeth: Ok so for the front I think I am using 245/35/20 the Proxys and for the back I'm am using 275/30/20. :whistle:
You are going to use staggered tires on a square set of wheels?? :facepalm: SMH
You could just run 245/35/20 or 255/35/20 all around! :gotme
Bravoval
Car: M35 Sport.
I know but this deal was sweet!
http://www.flickr.com/photos/bravoval/
The Bodyguard
Bravoval wrote:I know but this deal was sweet!
Good deal? Yes!! But since you've only ordered two wheels, I recommend you go ahead and order the other two for the front 20x9" +32 or +35 offset is perfect! :bigthumb:
The tires you have a the exact tires size I ran on my staggered set of WORK wheels. 245/35/20" 275/30/20" Hankook!! My wheels were 20x10"+35 front, 20x10"+45 rear! Good luck anyways. Wheels look nice, you will need a nice drop!! :dblthumb:
kontra-vers-E
I was kind of wondering about the 20X10's all around myself. Everyone I asked said no, do the staggered setup but that is't what I wanted. So I went to Butler Tire here in Atlanta and they advised the staggered look as well. So I got the TSW Stowes 20x8.5 245/30/20 Front 20X10 Rear 265/30/20 (not sure what the offest is), I am pleased with the look, but still think the 20X10's all around would look better. But this is what mine looks like now...
Bravoval
Car: M35 Sport.
:biggrin: I finally got the back ones on today. I had a blow out on the back end so I couldn't wait for the font to get here from the ware house. 275/30/20 on 20x10 Stance Sc5 wheels. :bowrofl:
Bravoval
Car: M35 Sport.
kontra-vers-E
Bravoval wrote::biggrin: I finally got the back ones on today. I had a blow out on the back end so I couldn't wait for the font to get here from the ware house. 275/30/20 on 20x10 Stance Sc5 wheels. :bowrofl:
Man the car looks amazing!!! I'm so jealous right now!!! I might go back and tell them to upgrade my front wheels to 20X10. Great pix of the ride by the way.
Bravoval
Car: M35 Sport.
:yesnod :naughty: :chuckle: :crazy: :rotflmao :woot:
I am blessed is all I can say. Thanks man I really like it 2.
06M4.5
Car: 2006 M45
what size are those wheels with offset? I thought those are 20x10 for the front and 20x10.5 for the rears. Now I'm confuse :gotme
Bravoval
Car: M35 Sport.
:bigthumb: ok. So when I was ordering the 20x10.5's I decided last minute to get the 20x10 all around for these reasons. # 1 I can rotate and the tires. # 2 the go cavity does not change between 10.5's and 10's.
I put the ones I got on the back because I had a blow out that day and it just do happens that I also got those in on the same day. :gapteeth: so my set up will be 20x10 all around with a 42 offset. I will be using 245/35/20 in the front to stretch the tire for future clearance purposes,meaning I will be getting a 2 inch deep eventually. I was told the 275/30/20 would be fine on front BUT because I'm dropping it soon I went ahead bought the tires fort THAT set up. I'm running 275/30/20 right now in the back and the stretch if fing nice! The pictures do not give justice. This set up came together real nice. I get my other set today and the rotors get here on The sixth of next week. Just to be clear this a factory set up in terms of the suspension right now. :dblthumb: I hope I have answered any confusion I may have created bye contradicting my self in terms of what I was doing. It just came to me last minute including the tire set up because of the opportunity I saw on Craig's list for 5 practically new tires. I will post more photos as I get the wheels, rotors, new wheel bearing, 2009 sport bumper swap, intake coil overs, and exhaust headers, manderal pipes and exhaust is to be decided. :dblthumb:
06M4.5
Car: 2006 M45
I understand now
Can we say looking at your pics that on oem suspension a 20x10 with an et42 will stick out passed the fender lip? Because it does
It will be fixed once you lower the car and adjust the camber.
Now have you tired this wheel in the front of the car?
I'm just trying to clear the questions on offset for others. I don't like when other members state the fact that 20x10.5 with et32 won't pass the fender lip when infact a 20x10.5 et45 does. Not everyone wants the wheel to poke out of the fender lip as many don't want to run stretch tires.
tires, lowering, camber, rolling, pulling & custom fender work are all tools to dial in final fitment. All this must be considered when ordering new wheels.
Bravoval
Car: M35 Sport.
:yesnod
Yes it does fit up font. But i had to put them in the back because I had a blow out that day in the back end of my car.
As far as the wheel size and how far it sticks out. 20x10 all around with a 42 offset. :dblthumb: :bowrofl: :chuckle:
THE WHEEL SLIGHTLY STICKS OUT AND HERE ARE THE PICS AND BRO LET ME TELL YOU IT LOOKD NICE!! :naughty:
http://www.flickr.com/photos/bravoval/8 ... hotostream
06M4.5
Car: 2006 M45
Yes it's a nice set of wheels, I got my cuz a set in the same color a few months ago for his white 2013 BWM 535xi
You should be able to tuck the rear with no problems as I also have 20x10 et42 but with 285/30/ (nothing needed to work but a drop).
kontra-vers-E
06M4.5 wrote:Yes it's a nice set of wheels, I got my cuz a set in the same color a few months ago for his white 2013 BWM 535xi
Damn, that's like the perfect stance right there!
