OutToWinPAHC wrote:Well to answer this and respond to Kamin. An auto trans is what you want at the quarter mile. These came with 4L60E's which is the same as a 700R4 but has an electronic OD and shiftpoints. You can use any trans you want with the LS1 as long as you get a converter for the application or a flex plate apapter.
As far as horsepower you just have to get it built to handle what you want in with respect. My TH350 can take 500-600 (and its at its max build). But in the future I will be going with a built 4l60 or 700R4
When built rightThe 700R4 4l60 600-700TH400 about 800700R4 800+TH350 400-600Powerglide 1500
i don't think soo
my friend's lumina SS (here in KSA we have the holden HSV under the name of lumina) broke his 4L60 that came stock with car and his car is ONLY 470rwhp...
THIS IS NOT HIS CAR...i've posted this so you can see what i'm talking about...it's also come in 4-door sedan styel too...
so do a LS1 swap with (either) the TH400(no over drive) or 4l80...
if the car is't for drag...i say go for LS1+T56 6 speed....
hope this help..
Ali
