Yes sir, the hooker kit includes the brackets that mount to the block, and a t56 crossmember. The bracket bolts straight to the block, n from there you bolt the c5 mount to that bracket with the included hardware n drop em right into the stock location after a bit of grinding or re drilling to the stock chassis mount point to accomodate the larger motor mount bolt. The hooker kit also includes a t56 transmission cross member specifically designed to bolt up the the 240sx stock trans crossmember location using the stock bolts. The mounts recommended by Hooker are Creative steel c5 mounts, and Prothane transmission mount:
https://www.creative-steel.com/store/in ... t_list&c=4
http://www.jegs.com/webapp/wcs/stores/s ... Grp=search
The hooker kit using a gto oil pan, is an affordable alternative to the complete sikky kit. I do not recommend using the gto oil pan unless your willing to cut/ reinforce the stock crossmember. Also you'll more than likely need to get an aftermarket baffle kit for the gto pan, and/or an accusump kit to prevent sloshing and oil starvation under high g forces. Although, if I could go back in time I'd probably just bite the bullet n go with the complete sikky kit, because I'm going to be using a lot of their other swap specific parts anyway n I believe certain items are discounted if you had already purchased the complete kit. Especially of you want a more "drop in" swap with minimal modification to the chassis.
I am the master of the run-on sentences, thank you.
