^ No wait. I'll be nice and save you from reading all of that.
There are 5 ways to lower a car:
1/ Cut spring
2/ lowering spring
http://cgi.ebay.com/ebaymotors/90-96-94 ... ccessories
3/ Ground contol
http://cgi.ebay.com/ebaymotors/GROUND-C ... ccessories
4/ Coilover
http://cgi.ebay.com/ebaymotors/90-96-30 ... ccessories
5/ Air suspension
http://cgi.ebay.com/ebaymotors/Ksport-A ... ccessories
#2,3 and 4 are your most realistic option.
#2 you will need high end aftermarket shocks to compliment with the stiffer rate from lowering spring. KYB shocks wont do. Tokico shoks might do. Koni shocks will do.
#4 is your optimal option for performance.
#3 is the intermediate hybrid between 2 an 4
Purpose of lowering a car is more than just atheistic reason, lose wheel gap, slammed, hellaflush etc ... It' for handling and performance on road couse, which I'm sure you are interested about. Lowering the car is lowering the center weight to the ground. Result will be less body roll, more stability during turn. Hence, it's the reason you might see SUV on drag strip, but never on track course. Weight is not their issue, center weight is.
I still can't believe you owned an Eclipse and not knowing the basic stuffs about suspension. Not trying to make fun of you or anything but this is just as bad as ... eh ... NVM ... This is pretty bad lol.
