If you wanna keep stock wheels, the SZ kit isn't a bad option if you can afford the 2-piece rotor. Otherwise, the new fluid, 300° brace and stainless lines combined with a Hawk HPS or Axxis Metal Master pad with new Brembo (real, not the Z1 crap) stock sized rotors will do just fine for street use. OEM sized stuff, figure about 30k street driven miles.vikesfankevin1986 wrote:This is SZ's kit
https://specialtyz.com/shop/300zx/braki ... e-kit.html
Do you think that isn't worth it?
What about something like this...
http://www.importpartspro.com/sttest1brup.html
If I add up front and rear rotors, the brake lines, and the front and rear breaks of the brands you suggested it comes out to around 670 bucks...That still isn't that cheap. The SZ kit is 200 more. Do you think its worth it? How long can I plan on the rotors and stuff lasting?
Repeated hard stops, i.e., track use, you'll want a larger, 2-piece rotor system. I'd steer clear of the Crapabono until a reasonably priced 2-piece rotor is available. Something that large def needs to be 2-piece.
