lowering springs/shocks and C/C plates
Manok
Car: 04 M45
I want to lower my 2004 M45 but as you all know, just adding springs isn't the right way to do things. I'd like to know what the most popular spring/shock combo is. Also, are caster/camber plates needed or can a shop align a lowered M45 to factory settings?
I'm sure bilstein or koni makes a nice shock for the M45 that can handle the spring rates of whatever lowering spring is out there, but this is my first Japanese car so I don't know.
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
You'll be fine with a spring only setup. I've been on Eibachs for almost two years now. Front drop of 1.0-1.1 & 1.1-1.2 rear drop is recommended. With such a minimal drop your OEM struts will not suffer any real damage. Yes, shops can re-allign this car back to spec as long as the car isn't too low. My Infiniti service guy suggested no more than what I stated above. Caster and Camber kits are pretty much out of the questions. Hell, it is hard enough to locate springs for this car!!!!!!!!!!
I'm sure others will beg to differ, but in my experience with other cars and this one I'm pretty confident in my statement. My previous car (Acura Legend Coupe) I was forced to upgrade both as you mentioned (struts & springs) at the same time due to the fact that the car was lower over 2.25 inches. I used Koni sturts and Ground Control Coilovers at the time.
Modified by CakeDaddy at 7:39 AM 10/16/2007
Manok
Car: 04 M45
Do you have the part numbers for the eibachs? Also, any other springs out there worth looking at besides the eibachs?
CakeDaddy
Manok wrote:Do you have the part numbers for the eibachs? Also, any other springs out there worth looking at besides the eibachs?
eibach part no. 6371.140. And in my opinion No, there is nothing else worth looking at. I 've seen the tein springs and they look stock from the pictures posted here. These was some talk of the tanabe coilover, but not sure if anyone went after them.zerothread/284469
Manok
Car: 04 M45
Ill give em a shot. Thanks for all the help.
caug1
Car: 03 M45
please let me know if you find anythig at all. i will take a set.
Manok
Car: 04 M45
I called alot of shops this afternoon with no luck. Guess were out of luck.
auditech10
Car: 03 M45
This has been talked about over and over again and almost everybody has called shops. They do not make them anymore and you will not find them. Do a search and you will see what I mean.
Manok
Car: 04 M45
auditech10 wrote:This has been talked about over and over again and almost everybody has called shops. They do not make them anymore and you will not find them. Do a search and you will see what I mean.
Yeah, but I gave it the ol college try.
CakeDaddy
keep trying. It took me a few calls to locate mine. We have a memeber here name "eskay" who located a set of eibachs back in April I believe. I'm sure some goober is sitting on 4 or 5 set in his shop somewhere.
Manok
Car: 04 M45
CakeDaddy wrote:keep trying. It took me a few calls to locate mine. We have a memeber here name "eskay" who located a set of eibachs back in April I believe. I'm sure some goober is sitting on 4 or 5 set in his shop somewhere.
I'm going to keep trying. If I manage to find some I'll let everyone know. I guarantee someone has some of these on a shelf somewhere.
