Lower injector seal location *pics for help
A place to discuss the systems and methods of tuning Nissan engines.
timmy_sivad
Car: sil80
does it matter where I put my lower injector seals? the ones that go into the intake mani.
I have sard 800cc injectors, there's a rubber seal up around section A. My oem side feed injector seals fit this part of my sard injectors. The top mount fuel rail i purchased came with those metal adapter discs that many top mount SR20det fuel rails come with. These discs cause the injector to seal around the narrower part B of the sard injectors. My issue with using these is they dont seal very well, but my oem ones do. Lastly will the fact that the injector is now sitting further out of the air flow stream cause any serious issues?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Your image isn't showing. You've placed it on a service that requires an account to view the image. You may want to use a free service that anyone can view, such as Photobucket.
How to post pictures using photobucket
Return to “Engine Tuning”
