Mr. White »
https://forums.nicoclub.com/mr-white-u164864.html
Tue Apr 16, 2013 3:56 pm
So, I have been battling with this whistle noise on my car for awhile. Whenever I apply throttle pressure, there is a whistle noise that presents itself. it gets louder the more pressure I put on the throttle. The car also back fires quite often. I thought it could be the gasket at the compressor inlet. So, i replaced that. The car responds much better (there was no gasket beforehand for some reason) now. But, the whistle is still there. It sounds like it is coming more from the intake side of the car although I can't pin point exactly and it only happens under load.
Also, my Profec b reads between -.63/-.64 which I believe is -13inhg of vacuum or so. I have checked vacuum lines visually and they seem to be fine. I replaced my TB gasket today as the old one was stuck to the Intake manifold. Idle is very lumpy, but it seems to drive fine under load disregarding the whistle at all rpms. I have also replaced the intercooler piping and couplings for better ones.
I really need some help guys, I am so stumped as to what it could be and dunno what to do next.
