allenms240 »
https://forums.nicoclub.com/allenms240-u128640.html
Thu Oct 04, 2012 9:32 am
ey there guys,
I am having a little t rouble with some oil pressure on a rebuilt sr20det.
I rebuilt it and got about 400miles on it currently. After initial warm up, the oil was changed, and again after 50miles. The oil in there now has 350miles on it. The other day I went ahead a installed my manual boost controller and have finally been boosting the motor. The other night I noticed that after boosting hard, the oil pressure was pretty low. I was running about 20psi at 2krpm and about 9psi at idle. This was the first time it has run this low, up until now I had acceptable values. The gauge sender is an electric GReddy unit so I don't think that is the problem. The next morning I started the car and was reading the usual 80ish psi for cold start.
The oil pump was replaced (bought of a user who has about 500miles on it from new), the oil sump o ring was replaced in the rebuild, and an ISIS oil pan is on the motor, so I don't think it is a problem with the sump.
Could it be this conventional oil is breaking down early because of the heat the motor is causing? I am using 10w-30 valvoline conventional. In a few days the amsoil 10w-30 will be here and that is the synthetic I will be using.
Any ideas?
EDIT:
I changed the oil today to Amsoil 10w-30 and slapped on a new oil filter. I went to get some food, the car warmed up, all pressures looked good. After I left the food joint, the oil pressure was as it was before, it's low and it's worrying me. I got to school and shut the car off and waited for ten minutes. I then started the car and the oil pressure was fine. I was reading acceptable oil pressures. I'm sure that if I leave the car on for over a minute though, the pressure will drop. So, what could be causing this low oil pressure? Need some ideas fast because it's my daily driver.
Allen
EDIT: The car drive fine, no exterior oil leaks, only low pressure. I'm scared to go above 3k though.
I know there is the oil sump o ring, an o ring on the oil pump to block, and 2 gaskets on the filter assembly. Are there any others seals I don't know about?
EDIT: The gauge is functional. I tested it with an analog gauge and getting the same results.
I plan to order all new gaskets/o rings, I just need to know what all there is int he oil system.
So far I have oil strainer o-ring, the 2 o ring/washers on the filter assembly, and the o ring between the block and the timing chain cover. What else is there?
Also, it seems to be a seal, not the actual pump, right?
