silviaNE wrote:I was refering to your aux injector an alcohol/water mix. It is not as easy as one might think to get that to work smoothly. i would recomend using an aquamist system standalone instaed personally. just my op.
Yeah, Sil80 was right, your gonna catch hell for that one. The aquamist kit is basically the same thing as any alcohol kit except you have a low volume pump and it sprays water. Granted, water has a better cooling effect on the combustion then Denatured alcohol does. But you wwon't ever catch me spraying somthing inside my engine that doesn't go boom when you put a spark to it.
My Alky kit could be tuned by your grandmother, besides, it will come 90% tuned for you already. You might have to adjsut the volume a small amount to tailor to your specific needs, but I'll be providing explicit directions on how to do so.
Denatured Alcohol burns 350 degree's colder then 93 octane pump gas. It also produces 15% more energy when ignited.
Alcohol is an easy way to increase the amount of boost your engine can run by 7-8 psi without detonation. Thats around 80hp to the wheels fella's.
WD
