slownslurious wrote:3) a 450 hp NA v8 would require more money than a supercharged one. The stock valve train won't support the engine speed required to acheive those kind of figures. You are looking at expensive custom ground cams, expensive forged high compression pistons, expensive forged rods, and expensive crank work (knife edging, chamfering) etc. In addition you will probably end up needing a standalone to tune an engine that close to the ragged edge. a v-8 it is, true, but at its meager 4.5 liters of displacement, a streetable 450 hp naturally aspirated engine on pump gas is not possible. And thats besides the fact that it would suck down low, which is what I'm building this engine for. If I wanted a screamer with no torque I would have left the ca18det and T04e in there. Been there done that, it sucked, I need more torque. Hence the v8 + eaton blower.
Ok this is horse****, because I've been talking to a VH engine builder for the last couple of months about how to go about it. I'm getting stock VH45 internals, a cam grind + shims for NZ$440+gst (that's around 250-300 bucks US), and GTIR inner valvesprings. Combined with my custom headers and freed up intake, plus tuned & chipped ECU, 450HP is possible.
You don't need forged pistons, forged rods (which the factory ones are anyway), expensive crank work etc for a safe 8000rpm.
You don't need a standalone, I've said it over and over and I'll say it again, the factory computer can be completely remapped as much as an aftermarket computer, it's additional (useless) functions like launch control etc that an aftermarket computer grants, stuff that you don't need on a 5 speed sports/thrash car.
As for the low down torque thing, yeah you have a semi valid point but you exaggerate a bit much... stop making sweeping assumptions. A highly efficient, high compression, modified & tuned quad cam 4.5L V8 is not going to have no power down low. Have you also forgotten that it has VTC ?
You're trying to say a motor like this won't be streetable... hell at least I'll have a throttle pedal and not a 'burnout button', it'll be driveable with a very controllable power & torque curve.
