OK I am building up a VH45 to accept some boost and I nee a solution for low compression pistons. I am trying very hard to track down any and all rumors but most are proving to be unicorns.
1) escort/other custom pistons. Cheapest I have found these is $2000/set. Not worth it
2) vq30det pistons. I have confirmed that while the bore for these is identical to the VH and they do have a nice dished design, they do not appear to be compartible because the overall piston high is dramatically shorter than the vh. Use of these will probably result in compression too low to do anything. UNLESS you use longer rods. TMS suggested that the 4.1 liter's rods might be a bit longer and use the same piston pin and crank journal diameter as the vh 45, but TMS later said that the difference in stroke between 45 and 41 is 6.7mm less so they will probably be too long. He said its possible to weld a rod to add or remove length but I haven't ever heard of having this done. It sounds very risky.
3)
http://www.cardomain.com/ride/2133309Check out that page, that gentlement from newzealand claims to be using forged subaru low compression pistons in his VH with a bore. I have contacted him and asked him for more information on his setup but I am waiting for info that may never come.
4) After extensively googling and reading other forums another person has confirmed that certain toyota supra pistons will fit (same bore) as the Q but no word yet on piston height and pin diameter, also have not yet confirmed which pistons (though that would be relatively simple since the supra has only had 2 engines).
If anyone has any additional information, corrections, or assistance on this matter please post it here. Lets try and get this thread going with all the information the community has on getting low compression pistons in the VH45de. My search has revealed that, if nothing else, there is a HUGE potential market for this engine once these questions are answered (ie this question has been asked by many people on many boards, and a lot of those people have projects in the works as we speak).
If you wish to contribute anonymously or to keep your idea secret let me know via email at
[email protected] and let me know which your preference is (anonymous I will post it up here for you or secret I will keep it a secret).
I need a low compression piston solution for my motor as soon as possible.
thanks
