1.) Define "normal maintenance." Most of us are a little more agressive about preventative maintenance. Does it include a mechanical ATF exchange, pan drop, filter replacement? Auxiliary ATF cooler installed? 3,750 OIC? Annual filter replacements? How often are the PS and brake fluid replaced? BG44K? ISO-HEET?dekota wrote:1.) Normal maintenance such as oil changes, etc on regular interval.
2.) I replaced the fuel filter and ran some fuel injector cleaner trough it.oh, I have not noticed the fuel pump getting loud.
3.) I do get the "transmission manfunction" message sometimes too.
Thats like telling a doctor you think your ankle is broken when you're actually having a heart attack. Completely farking useless and does nothing but waste time and money while the real problem gets worse.elwesso wrote:Saying that "transmission malfunction" and "low battery charge" mean nothing is TERRIBLY ignorant... it may not be what is immediately obvious. Just because it says "transmission malfunction" does not necessarily mean the transmission is bad, however it CANNOT be ignored because these things do not come on for NO reason!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You can just grab an air filter at your local dealer. It shouldnt be more than $10-$15. The seal on an OEM air filter is tighter and more uniform, allowing fewer dust particles to get past. Those large dust particles will damage your expensive (and sensitive) MAF sensor.dekota wrote:I am looking through my manual to find the part number for the OEM air filter, cannot find it anywhere - do you happen to know? Why is it so important to use an OEM filter? Are the others inferior?
Thanks again!
Actually its more like telling your doctor that your arm hurts while having a heart attack. Its not your arm, but the arm hurting is a symptom of a heart attack.... Of course, all codes must be taken with some degree of haste, because as we know some codes cannot be interprited absolutely...Jesda wrote:Thats like telling a doctor you think your ankle is broken when you're actually having a heart attack. Completely farking useless and does nothing but waste time and money while the real problem gets worse.
Fortunately, error messages have become more useful on fully computerized modern cars, instead of decorative. Of course, that computerization leads to its own set of problems.
Where did you read that? I just did mine, and it was a little involved, but not really too bad. The only really difficult part was getting the nut on the back of the lower alternator bolt. Otherwise, it's fairly straightforward. You gotta unbolt a few things, but nothing really hard. Just a little time consuming.dekota wrote:After reading how hard it is to replace the alternator...it is good news that it can be something else!
Is it the small diameter tube just behind the butterfly or one of the 2 larger openings, or something else? Regardless, all passages need to be clear. If your hoses aren't brittle I would recommend removing the throttle body for better access to the dirty ports. There's 4 allen head bolts and 4 hoses attached to the TB and it will pull out. Good luck.dekota wrote:BTW, when I open the butterfly I see something that protrudes up inside the body of the cavity, behind butterfly valve. Not sure if this is a sensor or bolt - but it is caked with gunk.
