"Low Battery Charge"
goody90q45
Car: 1992 Infiniti Q45 (sold)
Good to see you found the problem. Congrats on your persistence.
You might as well clean the IAC when you get a chance. If the EGR passage was clogged the IAC and its passage might not be far behind. It'll smooth out your idle too. Never saw you mention checking the codes on the ECU. It would be interesting to see what codes are there.
I have the same problem with my TB connector. Female connector got brittle, a couple of pieces fell off, and it doesn't snap shut any more. I wrapped a plastic cable tie from end to end around it and pulled it tight. Works great.
Q45tech
One must understand the symbiotic relationship between the 10 load steps provided by the TPS and the load steps provided by the MAF.
Disconguitity between the two [either from MAF or TPS] can often show the same symptoms.
