gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Wed May 16, 2007 3:26 am
i'm not really sure how the hydraulic is set up, but on the solid there is a little "watch battery" looking shim that sits under the bucket, and the watch battery sits on top of the valve. as far as i know, the hydraulic setup also has these watch battery shims, and my guess is.. if they are too far under spec (thin), it will make your lash too big and cause the ticking. Maybe you need to buy new shims, or switch shims around and get a few thick ones grinded down to fit.
That's what i did with mine.. mic'ed the shims, used feeler gauges, then got certain ones grinded down so all the lashes were in spec.
