nissan~240sx wrote:
EPIC FAIL
good luck
no its not... shut up
I have a 90 coupe. and there are no ID numbers to identify our keys so the only solution was to take out the passenger door lock. (im told the passenger side lock is a better.. maybe because of less wear)
for an s13 this is how it works... I did this in 8 minutes. while a friend was waiting for me outside.
- remove the door panel, - peal part of the plastic out the way. - put a 10mm socket unto the two nuts that hold the lock in place. you'll have to pull one of the rubber plugs off the door to reach the rear most nut. - pop off one metal rod that attached to the lock, (rorate the green plastic hub that holds it - sideways, its fragile look at it before applying to much force, its quick and easy if you can see it.)- now you can twist the whole handle casing out and reveal the lock.- unwind the metal wire around the lock and it slides off.
15$ at the lock smith and your good.
