DMiglia »
https://forums.nicoclub.com/dmiglia-u92701.html
Wed Apr 30, 2008 7:36 am
Here is an update. I took the car back to the dealership. They checked it out, compared the seat to a car on the lot, and said that it had the "same amount of play." They notified Nissan tech assistance, which indicated that it had had "complaints of looseness." However, the dealership said that there was no repair for this at this time.
Let's remember that this involves only the power seats, which I assume are in the minority for Altimas generally. Also, some people apparently notice it, others do not. Of those who notice, not all are concerned about it to the extent of seeking a fix.
I called Nissan Customer Service, 800-NISSAN 1, and left a detailed complaint. They asked what I wanted, and I said I wanted it fixed. I conclude that this may well be a design issue, and Nissan will not implement any extensive (read expensive) fix unless enough people make their voices heard to cause Nissan to believe that there is widespread consumer dissatisfaction. So, fellow NICO forumites, if you have this problem, start making calls and writing letters! Be sure to let them know that you can be made happy, if they acknowledge the problem, and fix it.
Let's see if there is strength in numbers!
