Andy,
I still have both alternators if you are interested. I didn't hear back from you so I assumed the issue was resolved.
Post by Fibre guy » https://forums.nicoclub.com/fibre-guy-u128603.html Tue Oct 20, 2009 12:54 pm
I believe it because there is no reason to overkill with charging. Alternators don't magically make electricity. They need more force to make more power. I don't see any need for anything above 110. With everything in my car on max I won't even see 90. I'm running dual I30 fans and HID lights with my silvia conversion. I only have a light stereo system with 4 4-way speakers. And the RB eats a only very small share.Booztd 3 wrote:For the guys that have done the quest alternator, I need to know why most of you selected the 110amp version. There is only a 10 dollar difference between the 110 and 125 amp versions, and they both have the same 2-pin plug, which is the same as the Z32 as well. They also appear to be identical when it comes to mounting
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
