Lit Sleepy Eyes Write Up
DALAZ_68
Car: 90' 240sx CA18det
vroom-chirp wrote:i cant remember now, but i think i ran it to a power (HOT) wire.
which one is the ''HOT'' ill assume its the one that in ur picture reads Supply?
le_ryan
Car: Mazda3
91 Nissan 240SX SR
for some reason i remember sending a hot wire to ground, and it worked ... but its been too long ago now, and i cant remember, sorry man.
DALAZ_68
sooo....ground the LED wire???
lol
le_ryan
Car: Mazda3
91 Nissan 240SX SR
sounds wrong, but that what i remember, send a hot wire to earth, for some reason i remember that making it work, but i could be wrong, with no switches here to make sure, i can only throw guesses in there air.
DALAZ_68
booo
well if i figure it out ill post it here unless someone coulod shed some light lol
xckid
Car: 2004 Chevy Blazer ZR2
yeah i had a switch like that, all you have to do is ground the extra wire, you have a pos, a neg. and the ground , and the ground is what lets the led turn on. if you dont want it dont ground it
DALAZ_68
xckid wrote:yeah i had a switch like that, all you have to do is ground the extra wire, you have a pos, a neg. and the ground , and the ground is what lets the led turn on. if you dont want it dont ground it
ahhhhhhhhhhhhhhhhhh
good to know...
chuki240
Car: 89 240sx
Great Write up man
ls1pressure
Good job to a great write up. I only have one other question, where can i find and how can i install the projectors like this: http://www.cardomain.com/ride/2504171
Team503_
Car: 92 Faded Green S13, 88 535i, 08 848
Great writeup, man, thanks! I'll do this Saturday, methinks.
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
just make sure ur motors arent slow/old
mine were, so when i would tap the button to adjust the heightone was always off by a inch and would increase the gapmade my car look retarded
Nacho_240
Car: 1991 240sx LE
While I was doing this mod, one of the metal prongs of my new switch touched the silver box underneath the cig lighter and sparks started to fly. I checked my mirrors, seatbelts, windows, wipers, lights and cig lighter but they all seem to work still. The lit sleepy eyes mod works fine as well.
Does anyone know this little box is for? Please help.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
I believe thats your auto. seat belt computer .pretty sure actually
Nacho_240
Car: 1991 240sx LE
^^^ That's good to know. My automatic seatbelts work perfectly fine so I guess it's safe to say that nothing went wrong.
Except one thing... I'd hate to be the type to ask question after question, but I need to. My headlights aren't at equal height and it bugs like crazy. I turned off the new switch, disconnected the "light control" fuse and even disconnected the battery. I was only able to move the headlight arm in one direction, after loosening the bolt like you mentioned a while back. The lid doesn't fall either like you said in your post a while back. Please help a brotha with a winking car in need. . Thx.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
If you took the right bolt out, it should have fallen, as thats the only thing holding it up, then its just a matter of tightening the bolt down as you hold the lid to the corrected height .
theres also an adjustment nut on the arm that connected to the lid, youll notice you can pop that socket off, then you can adjust the arm up and down by losening or tightening it... guess i gotta get some better pics to show.
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
Great write-up, just wished that there were more pictures.
Nacho_240
Car: 1991 240sx LE
I don't know why I didn't think of this before... I took out my extra headlight motor from the garage and experimented with it. It turns out the bolt holding the adjustment arm is of the "acorn" style and mine was just really jammed in there. A long breaker bar did the trick.
I just realized this write was written over a year ago and you're stilling helping people out with this mod. Thanks for your help Vroom-chirp... a great man indeed. I know, I know... keep it in the pants.
wahrheitoderpflicht wrote:Great write-up, just wished that there were more pictures.
I took pics of the wiring set up, but it was dark and I took them with my camera phone w/ flash. Don't think they'd be of much help.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
eh, im just giving back to a community that would do the same for me .
and yes, keep it in your pants bro lol
smiley405
ok so i did the mod looks cool now it looks like i have under glow cuhz my lights aim low need to adjust them higher well i was wondering what if i bought the h4 converter with hids will it look weird?
le_ryan
Car: Mazda3
91 Nissan 240SX SR
3. Using the headlight motor control button, lower the head lights to the desired position by pressing the button in and out, this can be tricky since the lids go down once you depress the button, and they stop once you press it in.NOTE: if you close them all the way, repeat steps 1 and 2 again.
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
works good was real simple thought I had messed up my turn signals but its all good !
Modified by destroyyourmind at 9:03 AM 2/27/2008
fayiz
Awesome tutorial. Your help has reached a guy in canada
Mine are a little out of line, but the bolt adjustment won't fix that. My left motor is a bit slower than the right, but I don't care haha.
You can manually lift it up to make it line up if you're taking pictures, and when i'm driving, nobody will notice.
don't mind the primer, or the wheel gap...that's being addressed this weekend, but here's what i got in under 30 mins:
Wiring:
Switch Location:
End Result:
Ignacius_Rebenga
Car: 180sx
Dude, I was having so much trouble at first because, prior to this project, I have never stripped or crimped wires in my life, but once I got it, it worked just fine. I even had the wrong switch at first, I had a 15amp switch and it wouldn't work, then I went back to autozone and got that same 30amp switch you're using, and its just so sexy
Ignacius_Rebenga
Car: 180sx
I have a question for u Vroom, I got that same switch you got and I'm mounting it in the exact same spot you did, and I wanna know how did you mount it? Did u take out that black piece and solder it to it?
240lookis
Car: 1990 240sx hatch
nice write up. i'm gonna have to do this to my piggy when i have the time.
Ignacius_Rebenga
Car: 180sx
Actually nvm i just did it
240coupelover1992
Car: 1992 240sx coupe SE
sr20detRcr1 wrote:<3 vroom
where do you get those lights below the headlights? where those black vents are??
JST2KWIK
Car: '92 Nissan 240sx Vert
Hey thanks a lot for the write up I did it all today in like 20 mins. I have a problem though. At first, the lit sleepy's worked gret. Now however, I get the lights in the right position etc. and turn on the lights in sleep mode with the switch off BUT it only stays in sleep monde for 5 seconds or less and then the head lights like reset themselves and go the rest of the way down and then all the way back up. I have the proper connectors and the exact same switch, and it was working perfectly. WTF? ha
le_ryan
Car: Mazda3
91 Nissan 240SX SR
weird, i never had that problem ... not sure what to tell you on that one man .
Ignacius_Rebenga
Car: 180sx
maybe the wire?
