USMCgetsome »
https://forums.nicoclub.com/usmcgetsome-u15451.html
Thu Feb 19, 2009 4:01 pm
ok so i uninstalled my ka24de manifold and deleted the egr and sealed it with EGR BLOCK OFF PLATE and jb weld. Then i took off my solenoids iacv/air reg and tested them with the 12vdc battery and watched them operate. Both are correct ohm read outs. I then lost my little spring to my iacv and replaced it.
I then reinstalled my intake manifold with new gasket and did the upper first then bolted in the lower. Tb also has new gasket. Replaced pcv valve. All new spark plugs gapped .044. New coolant thermostat 12" position.
Also, removed dizzy and man i sure as hell feel like i messed up the timing. I tried my best to put it back where it was and started her up and she backfired through the intake.
So then i removed the dizzy and lined up the 0 marker on the flywheel and reinstalled. Starts right up and idles at 750 all day. But is bogging when throttle applied and well she doesn't sound like she's firing right at all.
I think where my failure is that i didn't check to see if the cylinder #1 was at tdc when i lined up that 0tdc marker and reinstalled the dizzy.
Does that sound right to you? Also had her running and she heating up above normal temps. Checked vacuum and it's at 10 instead of the normal 23+25. It really sounds like i'm goofing but does this sound like i messed up the timing?
I'm gonna try it again tomorrow but with a screwdriver and another set of eyes to set it at #1 cylinder tdc. Give me some feedback and i'll post it up tomorrow. Btw it funny but i totally fixed the idle problem i was having lol.!!!!!!!!!!!!!! YES!
