I'm not sure you'd want to see pics of all my vehicles.
The fronty is an all black extended cab, with strategically placed paint chips, tree sap, and dents to maximize wind resistance (and reduce theft). The entire underside of the car was meticulously covered with oxygenized steel, for weight reduction of course. Mud flaps are cracked and broken... for brake ventilation. And my most recent modification was to rip down the sagging headliner... because it was just plain annoying!
The tracker is torn apart right now. The engine spun a bearing so that's getting a rebuild and the interior is getting completely refreshed so it's all ripped out.
The 88 Samurai is sittin on a 2" body lift, and 2" lift springs in the rear. The engine has low compression, and the carb runs so rich the crankcase stinks of gas after I drove it for 5 minutes. That engine will be replaced with as much of a N/A beast as is possible for these engines. 1.6l block (as opposed to the 1.3 it comes with), new internals, lightened crank pulley, ported head with enlarged valves, high lift cam, chevy small block valve springs, adjustable cam gear, and a weber 38 carb. It won't rev as high as the original 1.3, but it should be able to lay down a good deal of power when all done.
The 87 Samurai is bone stock. Except for the fuel injected 1.6l 16 valve engine I put in. Stock samurai has about 55hp. This engine puts out about 98hp. They're not big numbers, but they don't have to be since these things only weigh about 2300lbs.
(maybe I'll post some pics later...)
