Are you serious? Let's see, where to start; a) all sway bars ARE NOT similar in weight to each other, there are often times big differences, b) yes, I do know what sway bars do, thank you, c) if you have to ask why weight is a factor on a race car, you really shouldn't even be responding here, d) many cars come from the factory with hollow sway bars, and depending on the construction material a hollow bar can be just as stiff, if not stiffer than a solid one, e) in the future I would suggest you not comment on topics you have little or no knowledge about, f) I am frequently confused, but this is not one of those times.blacksrjdm wrote:Most sway bars are mostly very similar to eachother weightwise anyway. A hollow sway bar would be useless. Do you know what a sway bar is supposed to do???? It is to stiffen up the suspension. Why would weight be a factor. And to have the weight of the piece mean more to you than the function of it, is just poor thinking. Tuning the struts and springs isnt gonna change the sway bars, or how they act. This doesnt make very much sense. I think you may be confused.
Then, if you are so smart, then call around to vendors and find out what these things weigh. Reguardless, I am choosing quality of the sway bar over the weight. I would go for a good name bar and would hope that that company would have factored in the weight issue. Or, if you are building a "race car" Go to the racing section of the forum and see what kind of bars people are using. Do some research and find the best part for you application. Want the car to be lighter, start a diet.ITA240SX wrote:
wow man, get a clue.he's got an ITA car. and yet you mock him as "If he's building a "race car""a new sway bar with new end bushings and end links thats even only slightly stiffer and slightly lighter would be better for him than any "good name brand bar" solid bar.blacksrjdm wrote:
blacksrjdm wrote:Then, if you are so smart, then call around to vendors and find out what these things weigh. Reguardless, I am choosing quality of the sway bar over the weight. I would go for a good name bar and would hope that that company would have factored in the weight issue..
Actually, I'm not building a "race car", I already have a "race car" I've been racing for a few years now; I am just looking for ways to improve it's performance. And forgive me for thinking that by asking a question about sway bars in the TECH/SUSPENSION forum I might be able to get an informed opinion...what was I thinking And silly me, I always thought asking questions WAS part of doing research...I must be really confused...blacksrjdm wrote:Or, if you are building a "race car" Go to the racing section of the forum and see what kind of bars people are using. Do some research and find the best part for you application.
LOL, this is kind of how I feel at the moment:blacksrjdm wrote:What is ITA?????????? And good luck with it, but, I still am gonna choose the quality of the brand over looking for a lighter bar.
And if this is for autoX, I dont even wanna hear it. I'll probably catch some sort of hell for this but, AutoX is a waste of time IMO and takes little skill. I went to 1 AutoX event in my Acura last year for the first time, competed, and won my class, also broke an axle 2nd run where everyone else got 4 runs. There were 40 some odd cars in my class, and I win the first time out in a bone stocker Integra, where my time was actually faster than the class above me. If you are racing on a race track, like VIR or otherwise, I have alot more respect, but never heard of ITA, might be out of the loop, but also, how was I supposed to know that anyway??
Great spoonfeeding. You have alot of extra time I see.glitched wrote:Now to try and help out with some actual information:
Stock swaybars are hollow as well as several aftermarket replacements. Testing has found the tube is the strongest shape and while maintaining a proportionate wall thickness a tubular swaybar will provide only 5% less stiffness for one made out of solid metal in the same diameter but will have a significantly lower weight, sometimes a reduction as much as 10-20lbs. This has no heavy polar impact since its so low on the chassis but will impact braking/acceleration respectively.
OEM Sway Bar Options
S13: (Abs/lsd package) Front bar 25mm, 21mm in the rear.
S13: (se without Abs/lsd package) Front bar 25mm, 17mm in the rear.
S13: (non se) Front bar 24mm, 15mm in the rear.
All are tubular steel
Aftermarket options (you can kind of guess which may be lightest based on what is known of their construction)
RC Pipe swaybars Front and rear (need translation but they are topquality like Largus sways) http://www.autorefine.co.jp/
Largus - Front bar 31.5mm, 27.5mm in the rear. 3 way adjustable frontonly. Tubular steel construction. Stock type endlinks. Largus includesnew bushings with purchase. ^Will not clear SR20DET oversize oil pans(eg; greddy oil pan, not sure about ARC's). It will also not clear theYashio Factory Tension Rod braces...
Whiteline - Front bar 27mm, 22mm in the rear. Solid steel constructionand 3 way adjustable. Whiteline users their own specific blade typeendlinks
Tanabe - Front bar 30.4mm, 22mm in the rear. Tubular chromolyconstruction. Stock type endlinks
Godspeed - Front bar 30.5mm, 28.29mm in the rear. Tubular chromolyconstruction. Stock type endlinks. Note this bar uses CRUSH bendsinstead of mandrel on higher quality bars.
Progress - Front bar 27mm, 22mm in the rear. 3 way Adjustable front &back. Solid steel construction. Progress supplies a heims type endlinkon these swaybars.
Cusco - Front bar 28mm, 18mm in the rear.
Suspension techniques - Front bar 27mm, 20.64mm in the rear. Solidsteel construction. Stock type endlinks
Intrax - Front bar 29mm, rear bar 22mm. Comes with greaseablebushings/brakets. Stock type endlinks. Adjustable.
Addco - Front bar 28.6mm, rear bar 22.2mm.
- Whiteline swaybar blade type endlinks are not as well designed as the OEM supplied endlinks so that does impact the functionality vs stock links with eurathane bushings or aftermarket replacements. If using whiteline swaybars it is recommended that aftermarket replacements are taken into consideration
-Largus, Splparts.com and PDM Racing both produce a heim joint based replacement endlink solution for both stock and whiteline type bars. This will improve the performance of a swaybar by removing give/squish with bushings.
Now I see why you posted all that. I was wrong........oooooooooooooo.glitched wrote:
That's sweet, but yeah, definitely out of my price range. And with the little testing I get to do, I would never be able to take advantage of it's full potential. There was a guy a few years back who had adapted one of the Speedway bars to work on the 240, but I'm sure that took a bit of fabrication, and I have too many other items higher on the to-do list to be getting into that right now.5upra wrote:can't tell you a weight, but we use genesis technologies for our cars. Probably out of your price range but its a true race piece. http://www.genesisparts.com/in...oduct
Not knockin his post or anything... but I think I have seen this list somewhere before when I was looking to purchase some new sway bars....Dammitboy wrote:An EXTREMELY useful & well put together post by glitched.
Bravo sir.
Yup, dont remember where I got it from, but when i find good information like that I email it to myself and tuck it away in an archive folder. (makes blacksrjdm's jab at me for to much time and spoon feeding even more ridiculous)wackawacka wrote:
I........blacksrjdm wrote:Most sway bars are mostly very similar to eachother weightwise anyway. A hollow sway bar would be useless. Do you know what a sway bar is supposed to do???? It is to stiffen up the suspension. Why would weight be a factor. And to have the weight of the piece mean more to you than the function of it, is just poor thinking. Tuning the struts and springs isnt gonna change the sway bars, or how they act. This doesnt make very much sense. I think you may be confused.
That is it. Good callhai1206vn wrote:That list of sway bars comes from here http://en.wikibooks.org/wiki/N..._Bars
I do hope you understand that my previous post was aimed at you.blacksrjdm wrote:
god your ignorance is why people run far away from this site when they want some serious help. Glitch gave a good answer thats why people ask question. Contrary to popular belief people dont ask question to be flamed by ignorance or else they would be people like you. Im glad there was some real info in this thread usually you cant get much good racing info in here usually have to go to the autox/road race for real responses. I hate making post just to b****, but god blacksrjdm people like you piss me off.blacksrjdm wrote:
Modified by blacksrjdm at 5:41 AM 5/6/2009
