Yeah I have been looking for information on this.Empty V wrote:3rd was to figure out how to read the ATF dipstick. For some reason I can't figure this out. I'll post up some pics tonight.
You said 3rd twice, as well the underlined statement has some minor grammatical errors. It is still legible however and I am happy to hear you have been able to find the time to work on your vehicle from installing the missing link to using some spit shine on your headlights.Empty V wrote:I had a little bit of time on Saturday so I went to the shop and did a few things to the Q. First thing was to install my Jackson Autosport's R50 Missing Link which dramatically helped with body roll. Next thing was to polish my headlights because they've been looking like garbage. 3rd on the list was to troubleshoot my driver's side headlight. It been going out when going over bumps which usually indicated the switch but that was replaced not too long ago. Luckily I had an extra ballast so I swapped that out and it seems to have fixed the problem. 3rd was to figure out how to read the ATF dipstick. For some reason I can't figure this out. I'll post up some pics tonight.
Empty V wrote:That's what happens when you post from your phone and don't double check your work. I'm proud of you for picking up on those mistakes. I'm also elated to see that you're staring to learn grammar. Did you get that book I recommended? Now we just need to get those blue LED washer nozzles off of your hood and a GED in your pocket.
It bolts up in between your lower control arms with the factory bolts. You'll see it in the pics and they shipped to me in so-cal just fine.VG33QX4 wrote:where does this missing link you speak of go?
does it really make a noticeable difference? curious if they ship to the states and if so how much?
I gave up because explaining something to you 4 times is just not worth the effort.Innovazn wrote:I think you should have stayed with the Rotor thread as well and try to preach to all of us as to how Rotors warping = myth. I would have enjoyed learning from you.
Or was it the fact that everyone was against you on your statement saying "Rotors do not warp, the surface just becomes uneven" ......... Meaning..... WARPEDEmpty V wrote:I gave up because explaining something to you 4 times is just not worth the effort.Innovazn wrote:I think you should have stayed with the Rotor thread as well and try to preach to all of us as to how Rotors warping = myth. I would have enjoyed learning from you.
miamiheat3332 wrote:empty v can you post a picture of that bar you installed, im very interested, also how much did shipping run from canada? Im in PA so it should be less cost as socal is alot farther.
Yea, me too, except it's not snowing here, yet.CanuckQx4 wrote: Makes me wanna hop under my car even though its snowing out !! just to see where this goes
Thanks!Chris.m wrote:To adress number 4, on the ATF dipstick, the hot fluid range should be within the cross-hatched space . The cold reading should be between the two indentations on the dip stick itself.
Email John Jackson @ [email protected] and he'll send you a paypal request for $50 Canadian. Paypal automatically does the currency conversion. So far I've notice a fair improvement in body roll. Going around corners is fun again!CanuckQx4 wrote:Did you guys just email them to buy that bar or is there a checkout link Im missing?? Looks like it might actually help!!
The only R50 I've ever driven is the one I own so I can't attest to the differences. Sorry brutha.miamiheat3332 wrote:not to thread jack or go off topic, empty v your q is 2wd, how much weigh does the 4wd system add to the path/qx4, because i think without the 4wd your q is definetly quicker than a 4wd one,
also have you ever ridden in one that has 4wd? how much different is the steering response and stuff, i remember i was on safecar.gov, and it said the 2wd model had a higher rollover rating risk, im guessing cause the 4wd adds more weight that is low center of gravity.
