Congrats! I really notice it when turning, especially when getting on the freeway at moderate speeds. I think I used a 22mm socket on both sides, they should have been the same bolts for you. What did it say in the instructions? Did you torque the bolts to spec and re-torque them after a test drive? I did it to 100ft lbs.CanuckQx4 wrote:I just installed my missing link, car felt great but I didnt have much of a baseline to compare it to
Empty. did you notice you needed a 19mm socket for the passenger side bolt, but a 21mm for the drivers side?? I was curious why it was like that
The front diff is around 100lbs by itself, then you have to factor in the front cv's which weigh around 10lbs a piece, then the front driveshaft, and transfer case. All in all id say its probably around 250lbs. Its not that bad, considering the benefits the 4wd has over the 2wd.miamiheat3332 wrote:not to thread jack or go off topic, empty v your q is 2wd, how much weigh does the 4wd system add to the path/qx4, because i think without the 4wd your q is definetly quicker than a 4wd one.
Join NPORA, all new product info goes there...then if its lucky trickles down to this forum. If you want to stay up to date, just join.GRNMACHINE wrote:Thanks again for the link Empty. Never heard of Jackson or the Missing Link before. Seems like a very affordable and decent bolt on.
Glad to hear it worked out. It only took me 10min but I didn't have to contend with the salt and used an impact wrench to remove the bolts. I doused it with PB Blaster an hour before just to err on the safe side.GRNMACHINE wrote:Installed the Missing Link yesterday, took a quick test drive, feels tighter. Need to log some real miles to see difference. Bolts were both 22mm. I would recommend on soaking bolts overnite as recommended in instructions. Install takes from 10 minutes to 3 hours per instructions. I was on the 3 hour side. Bolts were a huge PITA to remove. 10 years salt and winter were not kind. And no, I did not follow the directions and soak the bolts overnite/24 hours.... If not for that, this product couldnt be any easier to install! Thanks again for the link Empty. Never heard of Jackson or the Missing Link before. Seems like a very affordable and decent bolt on.
