Lightened crank pulley + KA-T...worth it?
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
i get around 280 miles for every 13 gallons ( we got a 16 gallon tank). so you guys do the math about my mpg. lolz but before i put the pulley in i was gettin 250. and the most gas mileage that i got with the pulley on was 330 miles per tank, and i still had 3 gallons left when i had to fill up. i got 330 becuase it was pure highway driving. i get 280-300 from driving in traffic and highway.
Structure240sx
yea i want to get the whole ultra ss set mainly for the looks. i would like jsut having the asp pulley sittin there all shinny then the other black ones. plus i already got some looks into my car i might as well keep it goin and get some power out of it.
MarkEmark
Car: fully-built '95 240sx KA-T
LT_Z wrote:Geezus carbon would be kewl but it would probly cost $1k I wonder how much a custom aluminum driveline would cost even.
You guys know that Enjuku makes an 11 lb aluminum driveshaft for our cars (which is half the weight of the stock, 2-piece 22 lb one) for $450....
Now lets see 1/2 lb reduction in rotational mass for the pulley, or 11 lbs for the driveshaft!!!!!!!
LT_Z
The enjuku is a bolt in ? for KA24E ? that sounds reall nice !
MarkEmark
Check their site...they have them for 89-94 240's, so I'm assuming it can be bolt in for the KA24E...
TrunkMonkey
Car: 2000 Lincoln Navigator
the engine doesn't matter, as long as it's the same chasis.
-demetrius
TurboKA37
and pulley saves more than a 1/2 lb. more like 2 lbs. but yea that would be awesome to have all these lightened parts
Exar-Kun
Car: 2005 350Z
I have them all. first gear is nice and brutal with them.-chet
MarkEmark
Nice...what would you rate as the best bang for the buck?I was talking to someone who has the fidanza flywheel, aluminum driveshaft, ASP pulley and electric fans...he said the flywheel did the most, then the pulley, then the fans, THEN the driveshaft...kinda makes $450 seem tooooo much!
first gear in mine is pretty brutal as well (when my clutch ain't slippin)
Marc
TurboKA37
with the driveshaft and flywheel it should make less stress on the drivetrain when shifting right?
Exar-Kun
Car: 2005 350Z
well, the flywheels did the most probably...the pulley and drivesaft are about the same. electric fan I didnt notice at all :/ other than no clutch-fan squeal!
my transmission has got some gear lash, coupled with the drivetrain lightening and the B+M shifter, I get a lot of upper-rpm noise...
other than that, its all good.450 may sound like a lot, but I think its worth it. if you want a bargain, I may be selling mine for a custom C/F unit soon.-chet
MOTOP
Car: 04 G35 sedan
When I was buying my ASP pulley from RPMOUTLET they offered me a kit of small pulleys for like 80 bucks so neither one of my accessories is underdriven.
Just my 0.02 cents.
MarkEmark
-Chet...I would be interested in buying yours used...would it work on an S14? (I know Enjuku distinguishes between the S13/s14 in their sale of the driveshaft). how much would you let it go for?ThanksMarc[email protected]
LT_Z
Who are you going to have make you a carbon shaft ? I wanna know how much that is. I have the Fidanza and im getting the either the UR or the ASP, and the Fal fans.
Actually not to step on marks toes, but if he doesnt buy your aluminum one i would take it ! :)
Exar-Kun
Car: 2005 350Z
im not sure if it would work on the S14, It ma be awhile before I sell it, though. I got other things to take care of (like deciding on fixing my body work or not)...
if your car is a 5-speed non-lsd I would think it would work...-chet
MarkEmark
Ahh, well it's a 5 spd LSD S14...AND i just realized that they make a distinction between the driveshafts from enjuku, so I don't think they're a direct swap :(
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
No, they aren't a direct swap.. one is little shorter, but I don't remember which. Most likely it would be the s13's.
Remember reading that in a tech article somewhere
LT_Z
Exar lemme know when you want to sell it ! i will take it !
[email protected]
