light weight flywheel
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
anybody know where i can get a light weight flywheel, or one that will fit off of another motor, such as ka, or sr? i just finished all the mods to fit the ca transmission in, and dont want to use the stock stuff again, since i am going to be uprgarding quite a bit in the near future. thanks.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
install an SR flywheel and clutch, or do like I did and have the stock one cut down a few pounds.
My next project would be a 300zx transmission, SR clutch, and maybe some stronger halfshafts.
Paul
1991240xs
will the 300zx transmission fit onto the sr(or ca or ka) bellhousing???
Movingviolation240
I think it will.......
I hope it will.......
I will make it fit........
I will
controler
You say put the SR flywheel on the CA, but use a KA clutch on a CA? Wouldn't it be better to use a SR clutch and flywheel... ?
I guess my only real question is which fits better, KA clutch or SR clutch, on a CA?
1991240xs
I just remember someone saying that a lot of the nissan trannys were the same...isn't the 300zx transmission a lot better than ours?...seems like a great idea to me..if it needs some adapter or something..you should fabricate it and sell it Paul..and sign me up for the first one..i had crappy trannys-
1991240xs
i just emailed unstable about it...i found on some website that they were designing a swap kit for it(...but then again..they've been designing a whole vg swap kit forever and a day...they're not the quickest moving people)...but i emailed them and will post you what they tell me-
dan240sx
Car: anal lube
paul, did you ever consider getting a fidanza flywheel? 7 pounds or 9 pounds......... can't remember, but it can be had for about 400 dollars.
btw, my 91 ka24de will crush all ca18dets!
SWIFT_DRIFT
sweet you're back! but i have to break it to ya...i have a ka24te!
t = triple cams
my triple cams are more aggressive than your's will ever be!
dan240sx
Car: anal lube
there's no such thing as a ka24te! but hey, at least we have torque, more than those hondaboys will ever have! just this weekend i smoked a GSR by 12 car lengths. By the time i hit 4th gear, he was done!
my intake and exhaust help a lot. Swift Drift, good to hear you support the KA too! we're a rare breed!
why swap out a bigger engine for a puny 1.8? people these days!
SWIFT_DRIFT
i have a 90 with a ka24e right now, my SR will be here in oct. however my freind has a 92 with a ka24de in it, and i must say, that engine impresses me alot.
Movingviolation240
the 91-94 KA clutch is a stock replacement, but the SR clutch and flywheel would be an upgrade due to the fact that they are bigger in diameter. Also a KA flywheel WILL NOT swap onto the CA crank.
I think I'm gonna swap my CA bellhousing onto the 300zx transmission (that's all it takes) and stick an SR clutch and flywheel onto it. ACT clutch and either a Fidenza or JUN flywheel.
I KNOW the KA transmission, SR transmission (any year), and RB20 and RB25 transmission's all fit the CA when you use the CA bellhousing. I can't imagine the 300zx one being any different.
hope that helps a little,
PaulOrlando, FL
ca18datsun510
does it have to be a rwd sr20 flywheel to fit? will it bolt right on, or am i gonna have to fudge it? anybody know if an s15 6 speed would bolt up. i have that in my future plans. mostly just so i can say i have a 72 datsun 510 with a ca18det and a s15 silvia 6 speed transmission.
Movingviolation240
S15 transmission works, but it's not as strong as the S14SR transmission.
Also the FWD uses a different clutch than the RWD SR, so I assume the flywheel is different too.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
Yeah, I'm pretty sure the FWD and RWD flywheels are different, atleast for the SR.
JDM_1990_S13
Hi guys, i'm new to the board but not new to the CA18DET scene, i have had a CA18DET powered car for about two years now, and just have a question about something in this thread>>
i am very curious to how the SR20 clutch works in the CA18det, what is needed fro the swap and how hard is it, i am guessing that the spline os the same count and that the flywheel etc will bolt up to the crank, someone please shed some light on this subject, i am sooooo very intrested..
Aaron B
Movingviolation240
bolt in the flywheel, bolt in the clutch, your done, what more do you need to know
JDM_1990_S13
I really hope that i don't go out and buy the clutch and it doesn't bolt up so easy as you say... i'll do a check on a scrap yard clutch and see what's the deal
drumma022
Ok, well after discussing this with Paul, the RWD SR flywheel has the same bolt pattern onto the crank, same ammount of teeth and roughly the same size. However, I have not yet seen this setup in action. I HAVE talked to a guy who has the RHD silvia in the states, and he was telling me that the twin disk clutch (tilton i believe) for the FWD sr20det WILL work and run and do whatever you want it to do on the CA. :) I recently just replaced my 8-puck (came with the motor) for a 4-puck. Stock Pressure Plate-can we say chatter from he!!. WHY? Well it is the cheapest available until I can get some decent $$ to get the Fidanza SR fltywheel and the Spec Stage 3 disk/pressure plate for the SR. I am also waiting to see if somebody does the RWD SR setup. ;)
Regards,RayCA18DETOrlando
Parts left over for the inquiring mind:CA turbo manifold designed to fit a T3.Custom Downpipe to fit the T3 w/o2 sensor.T3 Turbo from the Z31 300zx with fittings for water and oilCA Stock Pistons4 x 370cc Injectors
ca18datsun510
if the flywheel is a bigger diameter, wont that muck up the starter?
Movingviolation240
no because it has the same number of teeth, the starter ring on the flywheel is recessed so it's the same diameter.
shawya
Car: 1989 240sx Fastback
I figured everybody could benefit from me posting on this thread and reading it again, since it covers lots of transmission type stuff. I wanted to know which transmission gasket I should use on my DET, since I want to take it off and check out my clutch. Would it be from the CA18DE or CA18ET? Just a minor thing, but gets major when you try to put the transmission back on and realize you don't know. Thanks.
boost_boy
If you have a CA18DET, then the CA18DE gaskets work the same!
mambastu
Interesting thread....
Sounds like the SR20DET flywheel and clutch combination might be the way to go. Can anyone recommend a decent uprated non-jap SR20 clutch and does anybody else make an SR aluminium flywheel other than Fidanza ?
Vetal
Has anyone tried SR20 flywheel and clutch on his car? Does it really FIT?
float_6969
It would be the cheapest flywheel option if it does. I know that some japaneese manufactureres make one for our motor, but they've GOT to more expensive than the SR one. Hmmmmm We'll see what more money brings...
NeedCAforS13
Car: CA swapped S13 coupe
I tried it... didn't work for me. Someone else tried it. Didn't work for them either (search for old threads on SR clutch fitment). It bolts up, and appears to clear everything fine, but WAIT! Try and bolt that transmission up to it, and DAMN IT stupid bellhousing doesn't clear it. By quite a bit. I suppose you could grind down your bellhousing, but I just went and got a performance CA clutch and stock flywheel combo:)
Oh and if you're wondering I have discussed this with Paul, and actually used HIS SR clutch and flywheel combo to try it out. It seems he was mistaken at the time this thread was started two years ago!
Sean
ca18datsun510
holy poop, have on been on hear that long? i was so much less informed then...
Nismo1182
Car: Z06
Old a$$ thread.
float_6969
yea, it is old. Old like your game is wit da ladeez!
