light weight flywheel
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
ok, so lets sum it up. s15 sr 6 speed will not work, does not use same trans/bellhousing setup as older sr's, ca's, etc.
sr clutch and flywheel do not work.
ka clutch will work on ca flywheel if you drill the pressure plate for extra pins, or just pull the pins out of the flywheel.
and, i believe boost boy said a fwd flywheel will work, and is much lighter, but slightly smaller in diameter.
anything i missed?
float_6969
How the hello is it that the KA (2.4L) flywheel will work and not the SR (2.0L). Unless they put the bigger flywheel on there to increase the torque? Regardless, A KA lightweight flywheel is much cheaper and eaiser to find then an CA and so are the clutches. Sounds like a plan to me!
NeedCAforS13
Car: CA swapped S13 coupe
ca18datsun510 wrote:ka clutch will work on ca flywheel
READ RYAN!:thinker lol
Sean
float_6969
I wasn't saying it was wrong jackarse, I was just arguing the logic of having a larger flywheel on a smaller motor. I didn't say that it was wrong. READ SEAN! Hehehehe.
Notchbackca
Car: guess...
who sells fidanza flywheels for the CA? or how can I get one to fit? :p
NeedCAforS13
float_6969 wrote:How the hello is it that the KA (2.4L) flywheel will work and not the SR (2.0L).
the KA flywheel won't work. It has a different # of bolts...;)
Sean
float_6969
Fidanza doesn't make flywheels for the CA. You'll have to get one from JapanLand. I think Jun makes one.
Notchbackca
Car: guess...
I know they do but its like 500 bucks so I was looking for an alternative
Vetal
Fidanza do make them...I've also seen CA18DET flywheel in Australia, but they were only 4kg lighter than stock (but cheap also).Spec promised to make one for CA18DET... Don't know their progress though
float_6969
I just checked Findaza's site and it says nothing about the CA. It's got ones for the SR20DET, but not the CA. Where did you find ones...
Jezz_s13
Car: Sil80 Track Car
fidanza don't make them, I spoke to a guy from fidanza a while back at the UK Autosport show.I have their catalogue here too.
It's a damn shame.
float_6969
bastards...
Jezz_s13
maybe they will if enough interest is generated, or that they are made aware of a demand?
Problem as with all US companies is that they only supply parts for domestic stuff or very popular stuff. For example someone on SXOC had to send pauter a std rod for them to copy a couple of years back, now they supply them.Perhaps something similar can be sorted with fidanza??I'm not sure what kind of order numbers would make it viable for them though.
just a thought.Mmmm fidanza FWs are cool. :D
Vetal
Jezz, I think many guys in UK have Fidanza flywheels, or am I wrong? Anyway, Spec would be much cheaper.
redamnavit
http://www.upgrademotoring.com...l.htm
I don't think the fidanza model would be too much cheaper than $400; I've seen SR20 ones sold for $439. Shipping may swing the numbers a bit.
Jezz_s13
no Vetal, no UK CA's have them a few of the S14 (SR) boys have them though.
The cheapest I've seen SR fidanza's for is $350.
The beauty IMO of the fidanza is the replaceable friction faces, paddles munch flywheels so would be damn handy to jsut replace the friction face of the flywheel every time you replace the paddle instead of having to skim the FW.Skimming it ok with stokc FW's as they are 2 a penny, but you don't really want to be skimming your JUN FW too often.
Vetal
I see :)OK, then we're stuck with australian and Spec (in the nearest future) :)
float_6969
Or the JDM companies. It'll just cost ya.
Jezz_s13
the Jun one is a decent wieght, 5.2kg. Std is 12-13kgAFAIK this is the lightest jap one, I could be wrong though.But yeah a bit pricey.
ca18datsun510
it doesnt matter if its a doch or sohc ka clutch does it?
Notchbackca
Car: guess...
damn that is a good deal on the flywheel... I'm getting one:D
NeedCAforS13
which one? we established the SR ones don't fit :confused:
Sean
Notchbackca
Car: guess...
CA18DE/DET (S12/S13/U11/U12/RT12) LIGHTWEIGHT FLYWHEEL 5.4kg $399.95
that one
NeedCAforS13
ahh:) the JUN one... cool stuffs
I thought you were talking about that SR Fidanza one Jezz was talking about for $350...
Sean
ca18datsun510
ok, so i just picked up my sohc ka clutch and.....
it doesnt fit.the bolt holes are so close, yet off just enough, that i cant thread in more then one of them. this is with all 3 pins out, since the dont line up either. anyone else had this problem?
Notchbackca
Car: guess...
just buy the CA one :P that way you know it fits...
Jezz_s13
I've just bought a S/H 800mile 5.2kg Jun F/W for £100 ~ $179 :):DResult. :)
Notchbackca
Car: guess...
FEH I SAY!
float_6969
Damn ur luck! But I guess that JUN ones weren't as bad as I thought they were. I had it in my head they were close to $500 for some reason.
Jezz_s13
they are $323 in japan (takakaira), not sure what shipping is.
Takakaira says they are 5.4kg, but Jun site says 5.2Kg.
http://www.takakaira.co.jp/asp...cat=2
