Your right on top of it yellow".
This guy shut it down!
rb25-water-pump-on-rb20-pictures-t226242.html
Never thought of jb weld and redrill id say it work as long as you prepped right and allowed to cure properly. I've even seen the stuff used in intake manifold ports over on hot rod forums and ls1 guys blocking off throttle body stuff.
Pump is ordered found one on ebay 80$ picture was right (one little 10mm hole no slot). Ordered a ZAP ebay radiator for 109$ buddy had good luck with one figured it werk. Should all be here by the end of the week.
.....huff
In the mean time im working on getting a mig welder so I can just start making my own stuff!!!!!!!!!!!!SO STOKED!!!!!!!
Anyone have any thoughts on a millermatic 252? I got a line on a used one.
Maybe too much for car stuff up too 1/2inch ....waste money?....
I eventually want to be able to weld ANYTHING you would put on a car.
tubeframe front end, cage, intercooler stuff, exhaust, eventually spool gun for aluminum etc.....
Maybe a tig is better for my goals?
Im a Subaru Hyundai dealership tech I dont have much metal work experience to say the least.
I have harbor freighter flux wire that tries too join metal but I used a millermatic 180 other day OMFG BOSS I went from garbage too good enough for me!
