mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Tue Feb 06, 2007 6:10 am
I saw a few old threads asking if an RB25 pump will fit on the RB20, but nobody really answered one way or the other... Except to say the pumps look very similar (rb25 bolt hole #1 is slotted and rb20 hole #1 isn't). Bad news for us RB20 guys -- the RB25 pump will NOT work properly. Check it out...
The Pink line traces the edge of the water passage under the pump. The yellow line outlines the slot size, and the green dot is the bolt hole. Finally the Blue shaded area shows the exposed passageway/leak area.
The slotted hole, the only visual difference in the pumps, is what causes the problem on the RB20. It will bolt up just fine, but because of the metal removed from the pump to form the slot, part of the water passageway will be exposed! This little gap is enough to cause the RTV not to seal very well in that area, or if it does maybe seal a thin coat, it will quickly blow out.
If you look in first picture, in the the lower left corner of the slotted bolt hole (behind the bits of RTV), you'll be able to see the water passage way. The second picture shows the end of a large zip tie shoved into the gap, it's a pretty good size hole (hard to see in pics)... Anyway in both pics, the pump is aligned and hand tightened on a few bolts. While it seems like some alignment/adjustment might "fix" the problem, the pump cannot be pushed up or right due to the bolts holding it in one specific place. This may just be a case of slight variances in the block casting, but I think there is a reason RB25/RB26 use the slotted hole and RB20 doesn't. I think the RB25 has a slightly different casting on the block under and to the left of the #1 bolt hole.
The RB20 water pump of course has a single non slotted bolt hole, which does a much better job of sealing off the passageway, and provides more metal to metal surface area for the RTV to seal:
How I found this out... I pressure tested my cooling system the other day, and found a huge leak out of the left side of the slotted bolt hole before I knew about this issue..
Ok, I figured I must have just missed an area with the RTV, so I removed the crank pulley, timing covers, timing belt, etc to re-install the pump. I took extra care to evenly cover all of the pump's mating surface with RTV this time around. I hand-tightened the bolts, allowed the RTV to cure, then torqued the bolts to factory spec in the factory order. Next I hooked my pressure tester back up to the heater hose pressure tested the cooling system to 2 bar. It held briefly but almost immediately blew a hole in the RTV in exactly the same spot on the left side of the slot. It actually blew out some RTV I squished into the back left corner of the slotted bolt hole (in a feeble attempt to help cover the gap, before I saw what the issue was)... Which means it wasn't even sealed from the back (block side) at all. I'd rather have it blow out on the engine stand than on the freeway... I guess that's the nice thing about pressure testing.
Well, your mileage may vary, but as far as I can see the RB25 pump is not a viable option for the RB20. Pick up an RB20 specific pump with a single bolt hole from Phase2 or a similar place.
Questions: Does the N1 water pump have the slotted hole? Did anyone else catch this sealing problem on their RB20?
Also If someone has a picture of their RB25 block without the water pump, I would like to see if there are any differences under and to the left of the #1 bolt hole:
Thank you for reading, hope this helps someone make the right choice when buying their water pump! And a final note to anyone currently running an RB25 pump on their RB20.... Your cooling system is running on borrowed time.
Modified by mello88 at 1:01 PM 2/6/2007
Modified by mello88 at 4:14 PM 2/8/2007
