meminto wrote:Why do they need to tomei cams specifically? Sometimes off the shelf is not necessarily the best option...You can have a set of cams made to suit your specific application, for a similar outlay of cost. As a suggestion, have a chat to an engineer about some options available...
Why Tomei? tried and proven, can't miss. What's to question ?Regrinds are anybodys' guess. Many are not worth a 5hit. I personally wouldn't go near any regrind unless that exact item tested by an individual source.Less of a problem with oz/nz cam grinder/suppliers vs u.s.a, from my observations tho.
Lots of early dyno threads on sxoc of intake performance cam only, which is exactly what I plan. Seen a miata 1.8L pick up 40hp with hella strong torque, intake cam only.Look at all the hot performing CA18s with CA16 cam mod, some S13s in the 11s.... and thats with any old $500 turbo.I would keep duration 265º or lower.My build philosophy is maximizing torque from the "li'l" guy tho, not sure if a fwd would like/can use that.
Do you really 'wanna' scream the motor to 8k ?
