lets talk motor mounts for second...
apex760
Car: 1990 240sx
zach-Ka wrote:O my... Cheap mounts are made cheap. dont get them. Solid mount = too much vibration IMONismo mounts are oem style but made wit a much stronger material. They are 30% to 40% stiffer than the stock mounts.
nismo are only stiffer then stock for little bitthen turn into stocks so just get stock mounts if its dailyunless u can deal with the vibration then get kazama
right now im running stock mounts and nismo transmission
slidestyle69
Car: 92 s13
ive used nismo motor and transmission mounts, worked well for me. If you like vibration then go with solid mounts, if not then get the poly's or nismo,avid,peak.something along that line
nissanman04
Car: '90 240SX, '95 Subaru Legacy
I have used hockey puck mounts, and IMO there is way too much vibration transmitted for a comfortable daily driver. Can't argue with the price, however.
Bumnah
Car: 1992 240SX, black. Bone stock.
Make sure you use atleast Grade 8 nuts/ bolts if you go the hockey puck way. If it's metrix Grade 10.9 (10.1?)+.
s14derrick
Car: 1995 nissan 240sx
if the hockey pucks are too stiff and cause too much vibration then i dont know if thats the route i want to go. seems like the nismos are nice and smooth but also not all that stiff. im wanting something in the middle. it seems like the kazama ,cusco, and project silvia mounts are all of the same design. so far im liking the jgs mounts or one of the 3 i just named . i can be persuaded
moulton712
Car: coupe, hatch, both s13s
i have a strut bar and have nismo mounts, but i also modded my mounts.
like i said i filled the holes with urathane, but then i welded a 1 inch stap of metal on the driver's side front. this will not let my motor move while heavy accelerating, but let the motor move when decel or heavy breaking. so it's sort of like a solid/non solid mount.
yes it did raise my motor up a little bit, but it's not like adding gas to my gas tank cant counter the center of gravity. i was still able to fit a strut bar
i have used the nismo transmission mount, and it didn't really give me what i wanted. (but i also like a stiff ride. also this car is not my dd)
for anything above stock power i wouldn't use hockey puck mounts. they can crack easy. especially crack in the winter. ever see hockey pucks shatter when you slap them with a stick?? i have
also i'm not saying get nismo mounts, i'm just saying i use modded ones.
projectdrift240kid
Car: s13
just go with the jgy they are not a bad price range and you won't have to f*** with them easy and less tools to use have fun
finalgear
Car: 91 240sx /90 240sx
show me a hockey puck shattering from when its hit with hockey stick? lol thats like saying i seen a foot ball explode when kicked lol, the hockey puck is tested for things like that extreme conditions, if it ever gets that cold to where a hockey puck freezes and shatters from being in an engine compartment i think that's the least of your issues with freezing, i also know a couple of guys that make 400+ hp on an rb25 that uses hockey puck motor mounts with no issues what so ever and its bin in his car for 7+ years now.
This is to the op: Me Farting in my seat while driving the car creates more vibration than these motor mounts create, spend the 12-18 bux make the motor mounts and try it for your self seriously, and if you dont like it all you wasted was 18 bux (that's what 2 meals at Mc Donald's?) but if you do like them you saved yourself a s*** load of cash to spend elsewhere.
Multon712: He lives in Colorado they will never freeze, you live in Maine and iam from NY our winters are no different and before i moved here to florida i had no issues with freezing i have also driven this car to NY and back twice with no issues on my motor mounts.
Modified by finalgear at 1:42 PM 7/22/2009
finalgear
all i have to say about the shattering hockey puck and being sensitive to temperature and failing is BS http://www.youtube.com/watch?v=U-HG0BLrniE
http://en.wikipedia.org/wiki/Hockey_puck
http://en.wikipedia.org/wiki/Vulcanization
Modified by finalgear at 2:09 PM 7/22/2009
scherger_16
Car: 1990 240sx SR20DET, 1993 Nissan D21 pickup
i used urithane to stiffen my stock mounts. i put it in the space of the stock mounts and in the transmission mount and stiffens it up alot for me i think the 15 dollar tube is better then spending money on the nismo motor mounts if your trying to keep cost down.
hai1206vn
Car: 95 s14 se
^^^^ that's the cheapest and easiest to get something a bit stiffer than nismo but still comfy enough. 3M Windo-Weld is your friend. I filled my stockers completely and the motor twists very slightly. In terms of vibration, i'd say it's about 20-30% more than the nismo. Here's minehttp://www.youtube.com/watch?v=fc50Wc0UFZ8 http://www.youtube.com/watch?v...lated
compare to thishttp://www.youtube.com/watch?v=Mg8P564ChWA
they're quite ugly but who cares
Modified by hai1206vn at 12:02 AM 7/23/2009
Chris28
Car: 92 s13 KA-T
I ran hockey pucks for like 3 weeks. Hated it. The whole car shakes and everything vibrates. If you drive your car on the street at all I suggest going with a legit mount.
I know have nismo mounts, they are noticeably stiffer than stock but still great for DD and track use. I suggest them.
SmithSR
Car: 240sx
+ Nismo
There's nothing cool about a regular car who's steering wheel vibrates in time with the engine at a stop light. Your lady will think your car is about to crap out and she will be looking for a new man with a decent vehicle.
FYI
jeff420
Car: too many to fathom
i have hockey puck motor mounts and they work great. i have a fully built ka24de with header and xcessive intake manifold with a healthy shot of nitrous. trust me, they will hold up. the vibration isnt that bad, but also you have to remember i also have coilovers and sit low so ride comfort isnt a big deal with me in my 240. i daily drive it too. im more bothered by not having ac or carpet
scherger_16
[QUOTE=hai1206vn]^^^^ that's the cheapest and easiest to get something a bit stiffer than nismo but still comfy enough. 3M Windo-Weld is your friend. I filled my stockers completely and the motor twists very slightly. In terms of vibration, i'd say it's about 20-30% more than the nismo. Here's minehttp://www.youtube.com/watch?v=fc50Wc0UFZ8 http://www.youtube.com/watch?v...lated
Modified by hai1206vn at 12:02 AM 7/23/2009[/QUOTEi did mine but i dont think that i got every nook and crany so mine might not be quite that stuff but it did make a difference i know the nismo ones are really good but its motor mounts if you want to save money i would recomend using the urithate. and besides if you want a nice smooth ride a 240 doesnt ride like a caddy.
S14AZ
Car: 1995 ZENKI 240SX SE Auto Ka
I'm switching to softer mounts due to daily driving.
I have circuit sport solid motor and trans mounts.
Car vibrates extreme when the A/C is blasting. If race car feel is what you want solids will do the trick.
I'm looking at the nismo ones and if I need them stiffer I will fill them with window weld.
I will also add in if you go with solid the hardware bolt and nut will vibrate off. Might as well use skateboard wheels if you want on the cheap.
You will notice a huge difference in vibration once the nut vibrates off and you might say to yourself I guess they just broke in after 4 years of use but nope lol! In this case cross thread is better than lock tight haha!
xDRAGANx
hai1206vn wrote:^^^^ that's the cheapest and easiest to get something a bit stiffer than nismo but still comfy enough. 3M Windo-Weld is your friend. I filled my stockers completely and the motor twists very slightly. In terms of vibration, i'd say it's about 20-30% more than the nismo. Here's minehttp://www.youtube.com/watch?v=fc50Wc0UFZ8 http://www.youtube.com/watch?v...lated
Looks pretty nice my buddy of mine use Windo-Weld on his 1990 Acura Integra when he were doing a auto to 5-speed conversion.
