StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Tue Mar 25, 2008 12:36 pm
Qproject, I have an '05 Q45. I've had it for 14 months now.My oil consumption is appprox 1/2 quart per 3500 miles. That's a LOT more than my '94 "t" model, but still not bad all things considered. The VK motor does have more oil consumption due to the different ring/cylinder design and likely other factors, so you'll probably not get consumption down to the level of the VH.
Like the others here, I strongly urge you to get the service history on the particular car you are interest in buying, then have an EXPERIENCED senior Infiniti technician do a complete and full inspection, bumper to bumper, including compression and leakdown checks on the motor. You will have to pay for this, but it's cheap insurance.
Then if you do buy it, be sure to FLUSH(not just change) ALL fluids, including brake system, steering system, and fan fluid. Get a complete wheel alignment and balance, change ALL filters. Get prices on these items, and take them into consideration when negotiating purchase price.
If after you buy it, you find oil consumption to be higher than is acceptable to you, you might want to try a trick I did on my '94. Take it out on a good hot day for a long trip where traffic is light and weather is good. Wind it out through the gears several times, at least 5, then drive it hard and fast for several hundred miles, loading the engine hard in top gear (after ensuring that your tires and brakes are up to snuff). This may well seat the rings even if improper break in did not. The motor can take it. so don't be fearful of damaging it.
Another point:Be sure to put GOOD tires on it, and keep them inflated to around 34.5 to 35 front and 37.5 to 38 lbs rear, checking pressures weekly. Change oil religiously every 3,000 miles or 90 days, using a premium synthetic oil and filter, re-flush the cooling system, transmission, brake system and steering system every two years or 30,000 miles, whichever comes first. Oh yeah, and DO buy the longest FACTORY extended warranty you can get. It's also cheap insurance, well worth the cost whatever it is.
The F50 is an excceedingly fine car, one that doesn't really get the respect it deserves. It does have a few flaws, like any other vehicle, but the many good things far outweigh the few bad things, none of which are hard to live with. The steering is a little vague and not as solid and precise as a G50, especially a pre-95 "t" model with HICAS, but it turns exceptionally short. The ride is a little firm (but it corners a LOT flatter than a G50). It's not as quiet as a Lexus, but is considerably faster and more responsive. The high beams are lacking in range, but the low beams are the best on the market. You can get replacement high beam bulbs that will increase light output but not too much added range from them. Premium models and later ones like the '05 have more goodies than you can shake a stick at, and they make driving enjoyable and fun.
In summary, IF you shop CAREFULLY, research the car you decide on, bring it up to as new condition in all respects, get the extended warranty, then maintain it properly, you'll have a fine car that you will enjoy for many years. Despite a few problems with early models, the F50 is among the most underappreciated cars in the business, much like the G50s were for so many years.
Let us know how you make out, and good luck to you.
